12-28-2016, 02:04 PM | #15 |
Drives: White 1LE Join Date: Dec 2016
Make sure you all take & post up some pics for the DIY!!
12-28-2016, 02:06 PM | #16 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
If the manual suggests doing this change, it may be best to have the dealer do it so there are no "issues" down the road. The eLSD isn't cheap, so I may have my dealer do it. This way if I have any issues down the road I can be like "the fluid was changed at the proper time by you". No possible warranty hassles then.
12-28-2016, 03:08 PM | #17 |
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4 Join Date: May 2015
probably not wrong, but since they're saying it's okay... i'm okay with it. i'm thinking of having the dealership do it as well for a better paper trail. although taking/printing photos of the process and sticking them with other records should also suffice and save a few bucks. I've never done it but it doesn't sound too difficult (famous last words
12-29-2016, 07:58 AM | #18 | |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
MJK3888 Instagram Link
05-30-2017, 05:21 PM | #19 |
05-30-2017, 05:58 PM | #20 |
Drives: ZL1 1LE Join Date: Oct 2016
I can give you the low down at Laguna if you want, swapping diff fluid is fairly straight forward.
05-30-2017, 07:15 PM | #21 |
Drives: 2016 Corvette Z06, 2018 ATS-V Join Date: Dec 2013
It comes out pretty milky and generally with significant shavings on the drain plug. Go check out the thread on Corvette Forum and there is a link to inexpensive Dextron from Amazon and a $6.95 cheap quart bottle pump to get it in the diff easily.
I also expect you will have a lot of extra room under the Camaro. The Corvette gets kinda tight back there due to the transaxle pushing right up to the rear bulkhead and rear sway bar. For some reason the Corvettes have both the fill and drain plugs totally loose. They easily can be removed from awkward positions with a couple of fingers.
Perry
16 SharkGrey A8 Corvette Z06 18 Cadillac A8 ATS-V |
05-30-2017, 09:25 PM | #22 | |
I may just use a large syringe to fill it... the transfer pump gives me an impression that there's a lot left in the tubing and less of an idea of what's actually making it into the car... |
05-30-2017, 09:48 PM | #23 |
Corvette Z06 uses 3 quarts. I think you are in the 1.x qt range.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 $9 pump that fits in the quart bottle. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Perry
05-30-2017, 10:49 PM | #24 |
The cheapo pumps were best, just grab one from your local store.
05-30-2017, 11:52 PM | #25 |
Drives: - Join Date: Mar 2017
It's very easy and inexpensive. Amazon has both the fluid and a pump that fits standard quart bottles.
15-20 min max - Jack the car up in the rear - The fill plug is on the drivers side about half way up, the drain is on the bottom in the center - They both remove with a 3/8" bit socket drive, the fill plug is a little hard to reach, a 5" extension makes it very easy. - Drain fluid, mine was black at 1200 miles - Clean both plugs well with a clean rag, again they are magnetic and I had a ton metal fragments on both - After draining, replace drain plug and attach pump to fresh fluid - Pump enough in until it begins to weep out of the fill port. - Some people have mentioned that after filling they drive around to let oil settle and refill, I didn't do this as I replaced about the same amount as I drained - Tighten fill plug Since there is such a small amount of fluid, it's easy to contain. I went to the track a few days later and car performed perfectly. There is zero reason why anyone should pay a dealer for this, it's so simple and you get factory fluid for $18/quart on amazon. |
05-31-2017, 12:16 AM | #26 |
Thanks gentlemen! I will indeed do this myself.. just in time for a 3 day track-a-palooza next week!
05-31-2017, 03:14 AM | #27 |
Drives: 2014 Cyclone mustang Join Date: Feb 2016
Nobody using BG fluids here? This is what most mustang owners are using.
2014 Cyclone/Select Shift/"/Sold
2016 ruby red GT w/3.55:1/resonator delete X- pipe/UPR catch can/Airaid "tube"W/AEM/J&M/BigWorm/BMR /SVE /ZL1addons/Redline/Steeda/BG fluids/ |
05-31-2017, 07:44 AM | #28 |
マスタング = 遅い
I think with the eLSD being a pricey piece, we all just want to 100% stick with what GM says to use.
