#15 | |
![]() Drives: 2018 camaro zl1 , 2007 porsche GT3, Join Date: Dec 2016
#16 |
![]() Drives: White 1LE Join Date: Dec 2016
1LE is definitely bread to live at the track off the showroom floor..... anything that can safely AND consistently put down supercar lap times is remarkable... especially ours coming with the added coolers, 10L oil, 2 piece rotors.
But the wheels are trying to be a DO IT ALL set [which is the main draw the the daily drivable track car anyway] I'd prefer a lighter 19 like some. I'm close to pulling the trigger on the 22lbs TSW interlagos 19x9.5/10.5 @300 each The Rohana RCF5 19x9.5/11 I believe are 20 or 21lbs range not confirmed yet @ $400 each I'm interested in the apex someone posted might be worth looking at also Dropping 20 or 30 lbs off the wheels easily will shave 1-3 seconds off lap times depending on the track |
#17 |
![]() ![]() ![]() ![]() Drives: ZL1 1LE Join Date: Oct 2016
APEX wheels are very popular in the m3 crowd and have no problems handling track duty. Probably one of the most popular track wheel sets for that car. I'm going to have to disagree with a lighter wheel taking 2-3 seconds off per lap, that is a HUGE amount of time.
#18 |
1-2 seconds on lightweight wheels is realistic strictly between accelerating you'll likely pull 1or2 car lengths on each straight section [10-30 feet per straight] and heavy breaking zones be able to start braking 15-30 feet later,
Multiple each of those a couple times per lap a total yield around 100-300 feet saved per lap coming around equals 1-2 seconds shaved easily - my personal exp and data using lightweight forged wheels and magnesium on other track vehicles |
#19 |
Based on testing with DAQ I still think that is pushing it. But, an argument for another time. It certainly can't hurt yah!
#20 | |
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
![]() Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
#21 |
![]() ![]() Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
I'd love for someone to make some 19" track capable lightweight versions of the new 1LE wheel design or the Gen 5 Z28 design.... so far no luck...
I might consider these.... they claim 25 lbs... 20's... Makes me wonder how light they could make 19's.... http://www.stancewheels.com/wheels/r...6-gloss-black-
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 Last edited by aa406079; 12-25-2016 at 11:00 PM. |
#22 | |
+1 |
#23 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 2SS Camaro Hot Wheels Edition Join Date: Sep 2015
I like your nickname for your car.......................
Zack46
2018 Camaro 2SS Orange Crush Hot Wheels Limited Edition Power Sunroof, 8 Speed Auto/Remote Start, NPP Exhaust Production Sequence Number 98 NEOCC Camaro Club Member Former Ride: 2016 Camaro 2LT RS V6 Hyper Blue Metallic |
#24 | |
![]() ![]() ![]() ![]() ![]() Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
#25 |
Mack da M1SS1LE
Drives: 2017 Summit White 1SS 1LE Join Date: May 2015
There is a section in the manual that outlines the procedure for preparing the car for the track. This includes installing the "Tall Deflector" and "Small Splash Guard" to the front brakes. These items, I believe, are supposed to be in the trunk on delivery. Am I wrong, did this change?
The "G" SEEKING M1SS1LE
#26 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS/1LE Join Date: Sep 2016
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE Join Date: Mar 2016
Yep the air deflectors for the brakes are different and already installed from the factory on the 1LE and there are no air deflectors in front of the front tires either. The only pre-track day preparations you would need to do is brake fluid and oil change.
IG: @NC_M1SS1LE
#28 |
![]() Drives: '19 SS 1LE/'19 Rubicon/'20 AT4 Join Date: May 2015
I plan on sticking with stock setup until the tires are toast, then put some reasonable street tires on the stock wheels (eg: Conti Extreme Contact DW) then get a set of 18s with NT01s or similar. I do like 5-10 day/year so it may take me a while depending on how well these tires last... I've ruined front tires on different cars after 1 or 2 days .. hopefully not the case with these tires.
