#15 | |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
#16 | |
You are correct about the front splitter and the air dams creating downforce in the front. The splitter slopes up on top and even if it didn't, it would still push the nose down from all the air pressure on top of it at speed. The air dams under the ZL1 direct air onto the front tires and also out from under the car, creating a vacuum effect under the nose. The hood also plays a role in downforce as it allows air to be sucked out of the engine bay to the top side of the car, so all the air going through the grilles doesn't build up pressure under the hood, then end up going under the car where it can create lift. The more things you can do to create a vacuum under the car, the better it will stick to the ground as speed increases. Many have watched that aero video and say the rear wing creates lift on the standard ZL1, because it appears to, except the ends, going by the color graphics on top of it, but you also have to take into account the vacuum created underneath it from being slightly tilted. A wing is the most efficient way to create downforce with very little drag. They still flow through the air very easily where a blade style spoiler doesn't. If you don't care about drag or any possible change in the aero balance, and prefer the look of a spoiler, then swap them out. I think the cars look good with either on them and will perform just fine on the street.
