Old 04-24-2025, 10:36 AM   #15
Sheldor
Drives: 2017 Camaro SS 1LE
Originally Posted by EFI Tuning View Post
I just install mine when needed and run the wire through the window. Put some tape on the paint under the wire then tape the wire down to that layer of tape. It will keep the wire from moving while driving and potentially putting fine scratches in the clearcoat. Just a lesson learned
Tim
For this method, do you use the stock O2 sensor location? or do you have an additional bung welded just for tuning that you use? and if so, do you just cap it off when not tuning? thanks
Sheldor is offline   Reply With Quote
Old 04-24-2025, 10:37 AM   #16
Sheldor
The no weld should be fine but make sure you can get a good seal. Any leak will corrupt the readings.
One side is fine. There is very little variance between banks.
Tim
"no weld" as in using the stock O2 sensor location?
Old 04-25-2025, 07:52 AM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
This thread is 9yrs old. DO you honestly think EFI is going to respond? He is a former sponsor that hasn't posted here since 2017-2018.
Yes, he means using the stock sensor location...remove a secondary(sensor 2) o2 that monitors catalyst efficiency.
