#15 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
The only snake oil is the advertisements that manufacturers spread about there product gains that are not achievable without some form of misrepresentation. You can call me the Mythbuster, I tell it like it is good or bad. The only way you're gaining 100 HP on this car is to either Heads, cam headers, exhaust cold air, OR add a supercharger or other form of Forced induction. You can read my recent testing of the best aftermarket bolt on parts available for this car today and get real accurate information with no bias. http://www.camaro6.com/forums/showthread.php?t=472259 Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#16 | |
Drives: 2016 Camaro SS Join Date: Oct 2016
Agreed! The best anyone can do is present the measured data without any marketing skew and let customers decide for themselves what is worthwhile to purchase. Everyone will find different value propositions in a given modification. Ted, us, and others are trying to extract the most out of what we have to work with.
Tim Quote:
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
Ted,
What are you seeing stock A8's put down in 6th gear on your dyno? I am curious to see the delta between the M6 and A8 cars. Thanks
#18 | |
M6 are 417 434 some slightly higher with more miles on them
#19 | |
Thanks.
#20 |
Yes his was exceptional both cars I drew baselines from had very low miles.
#21 |
Check me out on YouTube!
Drives: 2016 Camaro SS Join Date: Feb 2015
Have you done a PORTED STOCK vs MSD intake manifold test?
2016 Camaro SS - A8, NPP, 2SS, Nightfall Gray Metallic
11.68 @ 118 - CAI Intake - TSP 2" Longtubes - DSX Tuning Flex Fuel - DSX Tuned 11.91 @ 117 - CAI intake only 11.99 @ 117 - STOCK 1/4 mile 410 RWHP / 424 RWTQ - STOCK Dyno --- YouTube Channel: BadBowtieProductions |
#22 |
No sir.
#23 | |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
I will do that Ted.
thanks very much Quote:
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
#24 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
My bad.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#25 | |
#26 |
![]() ![]() Drives: 69 GTO, 05 GTO, 2018 Silver ZL1 Join Date: Jan 2012
Ted, Question!
I have a 2SS, A8, with Mishy intake. My Car has 10,000 miles, and still averages 27+ mpg on the Interstate....checking mileage the old way. Fuse 51 NPP is pulled...my 1 exhaust tip on both sides is black in a couple days after cleaning. So is my car still running rich in certain conditions, like hard city driving, but not cruising??? Is a tune needed to help this? |
#27 |
![]() Drives: Chevrolet Camaro SS Join Date: Mar 2015
Questions:
Do the rocker fulcrums interchange between the LS and LT? What about the valve springs? I know it's early in its life, but if they're anything like the LS3, some of use can expect a broken valve spring. My '14 SS, think g8, had a broken spring discovered while doing a cam change. Are the pushrods in the LT1 really stiffer than the LS, or do they need to be changed. Other than the pushrods, the other 2 are really preventive measures based on the LS platform. |
#28 | |
Camaro Again?
Drives: 2016 Camaro SS Join Date: Oct 2009
2SS, NGM, NPP, MRC, 6M, NAV, Blk Bowties, Split Spoke Gray wheels
