Old 12-11-2016, 07:31 PM   #15
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
There are two sensor part numbers, I ordered the SS part number, not sure what the difference is. The stock 18" rims fit great on the SS. I like the silver look for the winter and black for the rest of the year.
Though I need to switch brake pads, I can't deal with the dust!
SPARTAN sui is offline   Reply With Quote
Old 12-11-2016, 07:57 PM   #16
63falcondude
63falcondude's Avatar
Drives: 16 Camaro, 11 Stryker, 00 Explorer
Originally Posted by tricel1 View Post
No I didn't use the SS sensors
I used the sensors that came with the LT wheels
Awesome, just what I wanted to hear. Thank you very much!
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015
3000 1/8/2016 (TPW 2/1)
3800 2/1/2016
5000 3/5/2016
63falcondude is offline   Reply With Quote
Old 12-11-2016, 07:59 PM   #17
63falcondude
Car looks good! My LT wheels have the stock all seasons on them but when/if they run out I'll get some winters to replace them.
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 12-11-2016, 08:24 PM   #18
SPARTAN sui
PC Technician
Thanks! I have Blizzak WS80 tires on mine. They work well but I would consider looking at Nokian. It looks like they make top notch tires.
Old 01-11-2017, 09:42 AM   #19
63falcondude
The OEM LT sensors in the 18" wheels do work with the SS. Synced them up the other night. Anyone know if the tire pressures for the 18" wheels & all-seasons should be the same as the tire pressure for the SS runflats? Can I go off of my door sticker for these all-season tires?
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 01-11-2017, 11:54 PM   #20
DarkFangz1100
Drives: 2016 Camaro SS
My 1LT says to sit about 30 - 34 PSi.
DarkFangz1100 is offline   Reply With Quote
Old 01-12-2017, 08:51 AM   #21
63falcondude
Thanks for the info. I ended up going with 35.
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 01-12-2017, 08:59 AM   #22
63falcondude
I put this in another thread but I'll put it here too FYI. The wheel weights on the inside of the 18" LT wheels come into contact with the plastic control arm air deflector when close to (or at) full lock. Happens on both sides. I'm assuming that the LT models do not have these.
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 01-12-2017, 03:22 PM   #23
SPARTAN sui
PC Technician
How big of an issue is this do you think? What could we do to resolve it? Spacers?
Old 01-12-2017, 03:50 PM   #24
63falcondude
Not a huge deal to me, just unfortunate. I wanted to talk about it on the forum so others know that they might run across this issue. The worst case scenario that I can imagine would be the weights getting knocked off thus unbalancing the tire.
The only things that I can think of to fix this would be either:
1) Relocate wheel weights inward if possible
2) Trim or remove air deflector
or
3) Add spacers
These wheels will be coming off once the temp warms up so it will only be an issue while maneuvering in parking lots for about 3 months of the year.
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 02-25-2017, 03:59 PM   #25
suzook
Drives: camaro
My tire guy was able to rebalance my "winter" Lt wheels with the weight about 3/4 of an inch off the edge. No rubbing. I like how quiet these are compared to the fat runflats.
Hyperblue/JetBlack
Old 04-24-2017, 06:42 PM   #26
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
How wide are these front wheels?
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
