Old 11-22-2016, 10:06 PM   #15
JFM-jr
JFM-jr's Avatar
What was the verdict on push rod length?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 11-22-2016, 10:48 PM   #16
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
It is 7.850 for sure. I decided to go the cam only route, after discussing what I wanted out the car with the shop owner, he thought changing the stock heads would be pointless and extra cash wasted for what I am trying to achieve.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 11-23-2016, 07:10 AM   #17
Blk16SS
Blk16SS's Avatar
Drives: 2016 Chevy Camaro
Well it's gonna make power for sure either way. The fact that the heads would be in your hands and not address a few simple details is pure misinformation by the shop owner and here's the reasons why;
Even though the LT1 engine makes decent hp from a stock standpoint, the cylinder heads leave ALOT to be desired. First example would be the intake port. It's a 297cc port that "only" flows roughly 305cfm. From a V.E. standpoint, this may be the worst since the LS based engine came on the seen. I won't even get into how wacky the exhaust port is. Point is, I would take a great set of heads over cubic inches every day of the week. Nascar engines make 800hp while sporting only 358ci. This engine can also be your daily driver. I know we all have budget windows we have to stay in but I simply could not miss the opportunity to work those heads to some degree. Especially when they're being removed anyway. It's like baking a cake and not putting icing on it...
Blk16SS is offline   Reply With Quote
Old 11-23-2016, 09:13 AM   #18
oldman
Drives: SS 6 speed of course
Originally Posted by Blk16SS View Post
Well it's gonna make power for sure either way. The fact that the heads would be in your hands and not address a few simple details is pure misinformation by the the shop owner and here's the reasons why;
that is basically the WORD
Old 11-23-2016, 11:05 AM   #19
bybcous
bybcous's Avatar
My budget won't allow for the heads I originally had 5500 to do everything. I am coming out total around 4200 for everything. I'd rather keep that extra money than to purchase heads.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 11-23-2016, 02:38 PM   #20
bybcous
bybcous's Avatar
More parts arriving and I added the e85 flex fuel kit to my order.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 11-23-2016, 03:20 PM   #21
BravoMyles
BravoMyles's Avatar
Drives: Blue/Black 2017 1SS
Did the beer come with the build? I need to order from where you're ordering.. LOL
I'm curious to see your gains. I'm doing basically the same with a little different cam (Comp Cam Custom VVT grind - 224/237 .585/.579 116), but replace the intake manifold with ported heads on mine. Also staying pump gas with 93 octane in mine. Should have it back by next Wednesday.
It'll be a good fair comparison between going heads or intake manifold I think.
2017 1SS - Hyper Blue Metallic
Heads, Cam, e85, 3600 Stall, Full bolt-ons, MBRP exhaust
2010 2SS - Summit White - SOLD
CAI intake, Borla Atak axle-back (Summit xpipe resonator delete), custom ported TB, Texas Speed 1 7/8" LT Headers w/ Catless connections
Instagram: bravomyles
BravoMyles is offline   Reply With Quote
Old 11-23-2016, 03:22 PM   #22
bybcous
bybcous's Avatar
Well i was holding off on doing my car until the warranty expired, and then I saw your post and said F*** it, let's do this.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 11-23-2016, 03:31 PM   #23
BravoMyles
BravoMyles's Avatar
LOL I'm glad I could be of assistance. I was gonna hold off on mine, then some buddies started stuff on their 5th gens and I couldn't resist.
Old 11-23-2016, 03:49 PM   #24
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
You don't need to buy new heads, just get someone to spend a couple hours working on them.
You have allowed lots of new fresh in and given it the chance to leave equally as fast with the headers......leaving the heads completely stock would be a bottle neck to the $4200 you did spend.
Old 11-23-2016, 04:13 PM   #25
bybcous
bybcous's Avatar
I you are right that will be a good comparison.
BradfordCamaro, i see where u are coming from. I will see if we have anything local.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 11-23-2016, 04:22 PM   #26
6spdhyperblue
Drives: 2SS 1LE
Two questions here.
Is there a budget $750-$900 option to CNC our current heads yet?
Also, the cam will reduce dynamic compression, are we still expecting the same hp gains from e85 as we see on a stock cam car?
Old 11-23-2016, 05:05 PM   #27
Blk16SS
Blk16SS's Avatar
Originally Posted by Nicul15 View Post
Two questions here.
1) Typically a race valve job, tearing the heads down and installing the new springs should run in the $500-$600 range ,providing the spring set doesn't need balancing. For another $500 or so you could get them to smooth out that left hand turn in the exhaust port. You can leave that MONSTER intake port well enough alone. It's gonna pick up some air speed from the valve job anyway....
2) No need to worry about compression ratio. There's no VVT cam that would adversely affect anything to the point where the CR needs to be raised, i.e., milling the heads...
Old 11-23-2016, 05:15 PM   #28
oldman
Does that much smaller lift allow the use of the factory rollers?
