Old 11-15-2016, 02:32 PM   #15
gosutag
Left Lane Enforcer
Drives: '18 ZL1 1LE.
I have been running 93 only since I've bought the car.
Current Cars:
2018 Camaro ZL1 1LE
2012 Ford Focus SE
1994 Evo II
Previous Cars:
2017 Camaro SS
2014 Chevy Malibu LTZ
gosutag is offline   Reply With Quote
Old 11-15-2016, 03:41 PM   #16
Whitemaro6
Whitemaro6's Avatar
Drives: 16 Summit white, Ceramic white 2SS
One thing is for certain these cars love a big breath of dry cold air!
Whitemaro6 is offline   Reply With Quote
Old 11-15-2016, 07:16 PM   #17
MuhThugga
Poppycock
Drives: Pontiac GTO
Originally Posted by EFI Tuning View Post
There is on the LT1 platform. But E85 is the better option if you can get it and aren't maxing out the fuel system.
Tim
Sorry... I was making an assumption that timing would be advanced beyond stock. For a stock ECM it could slow you down.
Right, you can make adjustments in the tune to get a benefit from 100 octane, but Brian was asking about just going ahead and pumping it into the tank, which will not do anything other than cost more money.
MuhThugga is offline   Reply With Quote
Old 11-15-2016, 07:50 PM   #18
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
Agreed.
EFI Tuning is offline   Reply With Quote
Old 11-16-2016, 06:45 AM   #19
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
Thanks everyone for the great information.
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 11-19-2016, 01:27 AM   #20
TJay74
ok, so here is what we have found in logging data on the truck LT1 engines. The 5.3 trucks knock like crazy on 87 octane, they show to really need 91/93 octane to not knock.
The 6.2 trucks show knock events on 91, so they do benefit to have 93 octane as well. The 6.2 trucks state in the manual to only use 91 octane, you can use 87 in a pinch but it is suggested to get back to 91 ASAP.
With that the GM powertrain testing is done on 91 octane as it is available everywhere in the USA where 93 octane is not. As EFI-Tuning said, 93 wont make more power per say, it just keeps detonation from happening which will cause the ECM to drop you into the low octane table which pretty much takes 15° of timing away instantly.
Octane is a fuels ability to resist detonation. Detonation happens with timing is advanced too far and a sharp edge on the piston gets too hot. As the fuel is injected into the chamber and the piston comes up on compression stroke the hot edge in the chamber ignites the fuel charge, then the spark plug ignites the fuel charge as well.
Now instead of having one singular flame front moving across the combustion chamber, you now have 2 flame fronts. They move across the chamber and collide, that collision is what causes detonation and makes the pinging sound. The occurrence of detonation is likened with taking a ball peen hammer and smacking the top of the piston, if it happens enough or is severe enough it can damage the piston/valves and leave small marks on them.
The cooler the weather and the incoming air is, the less the chance of detonation unless the timing is just advanced way too far.
I have a station a mile from my house that carries 100 octane pure gas, I get it for $7 per gallon. I mix 6 gallons in my truck with the rest being 91 octane, brings my octane to around 93/94. I do the same thing in our Audi SQ5 as well. So far no detonation has been seen in either of them, now that it is cooler out I can run 91 and will be fine.
Old 11-19-2016, 08:30 AM   #21
My87z28
Drives: 1987 Z28, 385cid, '16 Camaro 1SS
Agreed.
My first question: are you TSloper?
Second question: many of us through the country do t have much access to E85. The closest station to me is a VP station that sells C85, but is 90 miles away and doesn't deliever drums. I have a truck but feel that I'd have a very hard time getting a full 55 gal drum out of the back of it (still something I'm contemplating). *** I've seen Race Gas additive advertised quite a bit lately where you can add to 93 octane and reliably produce 100+ octane. Would it be feasible (wise within reason) to go this route, while testing each tanks octane, and have the car tuned for 100-104 octane?
02/23/16: 1100, 03/16/16: 2500 # TGHR6N
03/16/16: 2500, 03/18/16: 3000 TPW : 4/11/16
04/8/16: built & VIN 04/11/16 - 04/28/26 : 4B00 Bayed QC hold, 04/29/16 : 4200 Rail yard
'16 1SS 6M, black with jet black interior, split spoke gray machined faced wheels, and black front/rear bowtie emblems.
My87z28 is offline   Reply With Quote
Old 11-19-2016, 09:04 AM   #22
EFI Tuning
EFI Tuning's Avatar
Yes
Technically it is feasible. However you won't net the same gains as E85. A major component of E85 is the cooling effect it has. This can't be achieved with gasoline.
Is it practically feasible? That would be up to the end user to decide are the gains worth the expense/hassle. I'd probably not opt to go this route personally until I have exhausted the hard part bolt on modifications. But that's just me.
Tim
Old 11-19-2016, 09:32 AM   #23
My87z28
Yes
Tim
Thank you,
I've spoken with Pray a few times and I'm very interested in the ported intake/TB. The E85/race gas wouldn't happen for at least another year or so as I'm very hesitant on voiding the warranty for at least the first two years. If there is one, hopefully any powertrane bug will present its self within that time. What are your opinions on running the ported intake/TB and RF CAI (along with 3" exhaust already done) without doing a tune? My concerns over this is a big reason I haven't placed an order yet.
Old 11-19-2016, 10:06 AM   #24
EFI Tuning
EFI Tuning's Avatar
Thank you,
You should not have any issues with that combination and no tune.
The Rotofab unit does not affect the MAF output signal in any appreciable way which is why it is the only unit I will be selling for the Camaro 6th gen platform.
Please let me know if you have any additional questions.
Thank you,
Tim
Old 11-19-2016, 10:15 AM   #25
My87z28
Thank you,
Tim
Thank you Tim
Old 11-19-2016, 11:10 AM   #26
Speedy1975
FASTER!
I agree with the above and would not run that race gas additive regularly. It may be "OK" for the occasional trip to the track, but it's really the same thing as Torco. You're really better off just getting a 5 gal pail of race fuel and having a tune specifically for it on the track. I run Renegade 109 unleaded in my supercharged Challenger at the track with great results. VP makes a similar product VP109. I get 5gals for $80.
As for all the boltons and such, my advice would be supercharge and be done.
Old 11-19-2016, 12:33 PM   #27
laynlo15
Drives: 2022 Lt1 A10
I've made all my drag passes on 93 octane, I run it on the street also. I'm planning on E85 this winter preparing for next spring. I'd like to run E98 if that will be of any benefit. I'll just buy a 55 gallon drum and use it only for drag racing.
