Old 11-09-2016, 07:16 PM   #15
GirlyNFG
GirlyNFG's Avatar
Drives: 2016 Camaro SS M6 w/ NPP
I keep waiting for mine to break, but so far shes strong.
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system,
Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion
28"x10.5" MT ET Drag 28"x4.5" M&H fronts
PB: 9.569 @ 151.05
GirlyNFG is offline   Reply With Quote
Old 11-09-2016, 07:39 PM   #16
Tmcbigblue
Drives: 2016 1ss black 6m
Do you all think the stock pistons would be good for a 150 shot assuming the tune and everything is good?
Tmcbigblue is offline   Reply With Quote
Old 11-10-2016, 06:38 AM   #17
SGDM
SGDM's Avatar
Drives: 2016 2SS
Originally Posted by jessrayo View Post
Yes, Vengeance Racing felt that it would be better to keep the exact same piston dimensions and compression ratio to avoid the need for additional engine balancing.
If I put in new pistons I want less compression so I can throw more boost at it. I like the idea that someone at ADM is working on the cylinder heads to decrease the compression a little there. I'm still thinking that eventually a 417 stroker kit and the Lingenfelter modified fuel system is going to be required to really use the boost all of these FI systems can make.... in reality at least $10K more than we paid for FI.
I am the one that had the head work done to lower compression, after much discussion with ADM, it just made sense and came in at 10.4:1. GM spent over 100,000 hours developing the new piston for LT1 and confident this is a sound decision.
Who Dares...Wins
SGDM is offline   Reply With Quote
Old 11-10-2016, 06:41 AM   #18
SGDM
SGDM's Avatar
Drives: 2016 2SS
Originally Posted by LibertyHill View Post
Makes no sense. The problem only exists with boost and because of the high compression. Shouldn't take too much engineering to create a piston that still balances but with lower compression???
Didn't we use head spacers or thicker gaskets back in the day???
Are the LT1 and LT4 combustion chambers identical?
Haha, dang, have not heard that in a while...yep, we use spacers to lower compression.
Who Dares...Wins
