Old 11-04-2016, 01:56 PM   #15
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Amazing information.
Old 11-04-2016, 02:53 PM   #16
DiGiam
DiGiam's Avatar
Drives: 2016 NFG SS A8
Originally Posted by Slem View Post
Thanks for doing this Ted couple questions, did you have a dyno graph of 1 7/8 ARH on stock motor only. Also being the stock air box is so good, what are your thoughts on just using a drop in k&n oiled filter ?
+1. I would think dropping in a green filter in the stock box would gain close to the same.
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
DiGiam is offline   Reply With Quote
Old 11-04-2016, 02:57 PM   #17
JANNETTYRACING
JANNETTYRACING's Avatar
NO SIR tested it ZERO
www.jannettyracing.com
email tedj@jannettyracing.com
Old 11-04-2016, 03:15 PM   #18
ULTRAZLS1
ULTRAZLS1's Avatar
Originally Posted by Snowblind View Post
Thank you for doing this, some of these results are surprising....especially the mid range torque loss with the MSD of around 30? from 3700 to 4100 rpm, I know you are mostly above 4k at the strip but that seems like a significant amount of power that is lost. How much do you think that offsets the gains ?
Its a shame Fraxam didn't fill up a 5 gallon jug of e85 and bring it with him, it would have been great to see those results.
GM hit it out of the park with this car it seems.
Given e85 is showing ~25 rwhp over 93 tune this would be a 480-490 rwhp car with bolt ons. Insane. Not much less than my g6x3 heads cam ls3. And this would be a faster car. I've seen heads/cam stingrays up to 550 rwhp
I think FBO e85 and converter will hit 10s for sure near full weight. Probably get close on stock converter even. If you added 60-70 rwhp to your 11.6 run you be damn close on stock converter
Old 11-04-2016, 03:46 PM   #19
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Great information, thanks!
One big question: was this all on the stock ECU tune, or was each hardware combo tuned?
Old 11-04-2016, 04:11 PM   #20
T-Man
Drives: 09 Cobalt SS Sedan
Any cam timing/injection timing optimization with the addition of the MSD intake?
Thanks for posting the results
T-Man is offline   Reply With Quote
Old 11-04-2016, 04:16 PM   #21
JANNETTYRACING
All of the aftermarket testing was tuned.
I tested cam timing in both directions and in all cases made less power than the stock cam timing map.
Ted.
Old 11-04-2016, 05:50 PM   #22
DiGiam
DiGiam's Avatar
Sounds like GM nailed the equipment and calibration down on this car.
Old 11-04-2016, 05:56 PM   #23
DiGiam
DiGiam's Avatar
Ted, do you think there is any power changing out the stock cat back with the 1 7/8 headers. The cat backs for these cars aren't cheap so just wondering if you've seen or tested anything
Old 11-04-2016, 07:55 PM   #24
JFM-jr
JFM-jr's Avatar
Thanks to Fraxum and Jannetty for doing this and sharing with the group here.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 11-04-2016, 08:06 PM   #25
shags
shags's Avatar
Drives: 2016 SS Garnet Red A8
shags is offline   Reply With Quote
Old 11-04-2016, 09:39 PM   #26
Gmanuel
Drives: 2007 335i
I'm a little curious how much more there is on the table if one went catless headers, and catback exhaust.
Gmanuel is offline   Reply With Quote
Old 11-04-2016, 10:20 PM   #27
Fraxum
Fraxum's Avatar
Ted, how is delta gains calculated?
Also I don't get my stock dyno # since your dyno is nicknamed the "Heartbreaker". Seems way too high.
See you tomorrow.
But hey everybody support Ted for how he gives us the real skinny. No BS. That is part of the reason why I did this. And to keep up with a certain Mustang....
Old 11-05-2016, 07:13 AM   #28
JANNETTYRACING
The ARH system includes a Cat back the long system was used in this case see this thread http://www.camaro6.com/forums/showthread.php?t=436608
