Old 10-25-2016, 01:27 PM   #15
Mojave
San Diego Head Tuners
Mojave's Avatar
Drives: 2016 Camaro 1SS ,NPP,MagRide, A8
I measured both with a DB meter and they are the same at idle at least
Originally Posted by 63falcondude View Post
If you leave it in tour mode, it will be quiet (relatively) when you start it up. Tour and Snow/Ice are supposed to be different sound levels but the two sound the same to me.
2016 1SS A8, NPP, MagRide, Black Rims
My 5th Camaro (3 Gen5, 1 Gen4)
Member of San Diego Head Tuners
https://www.youtube.com/c/MojaveKY
https://www.instagram.com/mojaveky/
https://twitter.com/MojaveKY
http://dinowax.refr.cc/bryanm 15% off DinoWax orders
Mojave is offline   Reply With Quote
Old 10-25-2016, 01:52 PM   #16
6spdhyperblue
Drives: 2SS 1LE
for quiet startup you will need to go into the menus and set the exhaust to stealth. thats the way to get a quiet startup
Old 10-25-2016, 02:11 PM   #17
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Is it noticeably quieter?
Emoto is offline   Reply With Quote
Old 10-25-2016, 02:13 PM   #18
merlin803
merlin803's Avatar
Drives: 2016 Summit White Camaro 2SS
I find that even if it starts in tour mode that if you have NPP that it still starts very, very loud and then after 10 seconds or so it quiets down. My neighbors have to hate me.
I have had people walking behind my car when it starts in Tour mode and it startled the crap out of them.
merlin803 is offline   Reply With Quote
Old 10-25-2016, 02:15 PM   #19
Emoto
Sure, why not?
Emoto's Avatar
Definitely barks when you start it. That's why I leave my garage door down for a bit when I start it in the morning. I will experiment with the stealth setting.
Old 10-25-2016, 02:36 PM   #20
EXSSIVE
EXSSIVE's Avatar
Drives: 2016 Camaro 1SS M6
The snow mode essentially puts the exhaust into stealth mode in which, unlike in tour mode, the exhaust valves stay closed even when the engine is revved.
EXSSIVE is offline   Reply With Quote
Old 10-25-2016, 04:20 PM   #21
6spdhyperblue
Drives: 2SS 1LE
no comparison
Old 10-25-2016, 05:19 PM   #22
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Driving it quietly out of the neighborhood isn't really that difficult no matter which mode it's in IMHO. It's just the loud startup that I can't control. If NPP would allow you to close the valve for a quieter startup on those early mornings I would take advantage of it but since I can't, I pulled the NPP fuse weeks ago so my valve is open all the time.
Dysan911 is offline   Reply With Quote
Old 10-25-2016, 06:39 PM   #23
schwartzki
Drives: 2017 Jaguar XE 35t RSport
You can control it, just go into Engine Sound Mgmt and change to Stealth. Closes the valves even on start up. Use it on those early morning.
schwartzki is offline   Reply With Quote
Old 10-25-2016, 06:41 PM   #24
schwartzki
If you want to change the startup noise and forgot the night before, just Press and Hold the start button with no pedals pressed and after about 5 seconds it will boot the car ignition on and able to change it before you startup.
Old 10-25-2016, 07:04 PM   #25
StateOfMind415
StateOfMind415's Avatar
Drives: 2016 Camaro 2SS NFG M6 MRC NPP
Originally Posted by Jimtasteek View Post
Are you able to engage Snow/Ice mode before starting up? I don't have my car yet but I do start work early and don't want to upset the neighbours if possible...
As stated above, you need to hold the 'Engine Start Stop' button for about 5 seconds to access 'Accessory mode'. Then navigate to Snow/Ice Mode and turn on the car.
In regards to sounds with Tour vs. Snow/Ice mode...
Touring will "bark" at cold start, then the values close immediately after. If your driving, the valves stay closed until you pass 3k rpm and/or step on the accelerator pedal more then 50%.
Snow/Ice mode will keep the valves closed at all times.
StateOfMind415 is offline   Reply With Quote
Old 10-25-2016, 07:12 PM   #26
Dysan911
Dysan911's Avatar
Originally Posted by StateOfMind415 View Post
As stated above, you need to hold the 'Engine Start Stop' button for about 5-10 seconds to access 'Accessory mode'. Then navigate to Snow/Ice Mode and turn on the car.
Even on startup?
Old 10-25-2016, 07:20 PM   #27
StateOfMind415
Even on startup?
On start up Touring will be loud for the first 2-3 seconds, then the values will close.
On start up with Snow/Ice mode (by accessing through Accessory Mode), valves will stay closed when you turn on the car (stealth mode).
Old 10-25-2016, 08:08 PM   #28
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
can anyone confirm that Stealth mode is tied to Snow/Ice mode? I haven't seen that anywhere. that would be nice since going through the menus is not convenient.
also, if engine was shutdown while in Stealth (Snow/Ice?) mode -- will it keep the valves from opening overnight?
crazydmc is offline   Reply With Quote
