Old 10-30-2016, 09:56 AM   #15
toohighpsi
Drives: 2015 C7 Z06 M7
Originally Posted by 1slowssm6 View Post
rpm motorsports has been faster with their 6g hci/nitrous think it was 9.6 but i heard they went 9.4 at dragging rights last weekend
Very cool, thanks for the heads up! Nice run and video, didn't find any timeslips, wondering what 60' they were cutting - looked like a really good launch. It seems that it would be as crash0117 ran 9.8s at 143 and they went 9.6s @ 139. Gotta be a pretty good 60' to go .2 faster with 4 less MPH on similar cars (I'm assuming both cars are running stock torque converters).
Now that I think about it, N02 cars might have an advantage in 60' area, since they add a fixed amount of O2 regardless of RPM. They would make the most torque at lower speeds and then torque would fall off more with higher RPM when compared with a boosted engine (PD or turbo) which hold a fairly linear increase in O2 across the entire RPM range.
Old 10-30-2016, 10:36 AM   #16
AndyUK
Drives: 2017 Camaro SS
unless they are using a progressive controller
AndyUK is offline   Reply With Quote
Old 10-31-2016, 10:11 AM   #17
crash0117
Drives: 2016 1SS Camaro
You are correct they have ran 9.63 @138 on slicks. I was with Ryan(RPM) at Draggin Rights and he only ran his 6tg gen once in a grudge race and he ran 9.84.
crash0117 is offline   Reply With Quote
Old 10-31-2016, 10:19 AM   #18
crash0117
He cut a 1.41 60 ft. He's running a progressive controller and launches on virtually motor before he really brings the power in.
Also both cars on stock trans and converters.
Old 11-01-2016, 04:21 AM   #19
Obsol3te
Obsol3te's Avatar
Drives: 2015 Mustang GT PP M6
Great runs man, congrats!
'15 GT PP M6 763RWHP @ 8100RPM 3740lbs
3.2LC KB, ID1000, Boundary OPG, TSS CS, KB BAP, SCT X4, Palm Beach Tuned, Kooks 1 7/8 Catted LT's, Magnaflow Comp. Cat-back,
Mantic Twin Disc, MGW Short Throw, Maximum Motorsprots CC Plates, BMR Cradle Lockout, Eibach Pro-Kit, Proj. 6GR 19x10 ET35 19x11 ET50
Lumar 35% Tint, UPR Floating Pony, MMD Decklid, BlackVue650GW Dash Cam
Obsol3te is offline   Reply With Quote
Old 11-04-2016, 11:55 PM   #20
toohighpsi
Is there an orifice in your bypass reference line? Pull the line from the bypass and see if there is a silver or gold restrictor in the bypass connection. Removing it from the bypass might help your launch if you're not at the limit of the tire.
