Old 09-13-2016, 01:00 PM   #15
Kaizer_911
Kaizer_911's Avatar
Found this in my manual for my 17.
I think I remember reading in a 2010 manual (which I will have to dig for) about a battery saver feature in the manual transmissions activated this way. Not sure if same or not.
6000 - 07/08/16 | Club F1FTY
Old 09-13-2016, 01:34 PM   #16
KenH.
KenH.'s Avatar
Drives: 2016 2SS M6 NPP MRC
Originally Posted by SkipNWis View Post
I read they other day riding with you hand on the shifter isn't a good thing? I seems to always have my hand resting on the shifter ?? What's your Take on this ????
I never leave my car in gear. Hill or no hill. I've tested the parking brake on a steep ass hill facing up and down. short of someone hitting your car it is not moving.
SkipNWis
Yes it can be bad to rest your hand on the shifter. It's not bushings that are the problem it's your shift forks. When you push/pull the car into a gear the shift fork applies the pressure to move it. If you rest your hand on the shifter with any amount of push or pull force you could be causing those shift forks to ride against the gear causing premature wear. Your mileage on this will drastically vary based on how hard your hand rests against the shifter.
Personally I rest my hand to the side of the shifter with my hand around the knob but with no pressure against it.
KenH. is offline   Reply With Quote
Old 09-13-2016, 03:22 PM   #17
Flashpoint135
Flashpoint135's Avatar
Drives: 2016 SS
"Parking
If the vehicle has a manual
transmission, before getting out of
the vehicle, move the shift lever into
R (Reverse), and firmly apply the
parking brake. Once the shift lever
has been placed into R (Reverse)
with the clutch pedal pressed in,
turn the ignition to OFF, and release
the clutch."
So how do you "firmly apply" an electric parking brake?
(not a real question, just thought it was funny)
Flashpoint135 is offline   Reply With Quote
Old 09-13-2016, 03:25 PM   #18
Kaizer_911
Kaizer_911's Avatar
Originally Posted by Flashpoint135 View Post
"Parking
the clutch."
Never noticed that but that is funny. Press that button with authority I guess then lol.
Old 09-13-2016, 04:00 PM   #19
Com69
Drives: 2016 Camaro 2SS 6M Nightfall Gray
"Parking
the clutch."
Same way you "slam" your cell phone when hanging up on someone. Push(or pull in this case) the button multiple times, angrily, while swearing and muttering.
I really do miss hanging up on people the old fashioned way, soooooo satisfying.
Com69 is offline   Reply With Quote
Old 09-13-2016, 04:05 PM   #20
jlagman
jlagman's Avatar
Drives: 2016 Camaro SS
Originally Posted by laborsmith View Post
That applies to the first production year of the 6th generation Corvette.
Laborsmith
That might be where I remember seeing it, but I do remember hearing/reading about parking in reverse for the six-speeds. Me personally, I park in second, a remnant from my ricer days.
jlagman is offline   Reply With Quote
Old 09-13-2016, 04:17 PM   #21
MovieGuy
MovieGuy's Avatar
Drives: 2016 Camaro 1LT
What are you going to do when that parking brake malfunctions? My experience over the years has been that parking brakes tend to be highly unreliable. Unless things have changed your parking brake is not hydraulic like the rest of your system. It works by pulling a cable. Cables stretch and cables brake. I would never entrust my car to the parking brake. All I use the brake for is a redundant safety step. I trust the car being in gear to hold it in place. And the best gears to do that are your lowest gears which are Reverse, and first.
http://www.camaro6.com/forums/image.php?u=115947&type=sigpic&dateline=1461721697
Life after retirement
MovieGuy is offline   Reply With Quote
Old 09-13-2016, 05:59 PM   #22
KenH.
KenH.'s Avatar
Well if it fails hopefully ill realize before my car rolls away. Is the ebrake in our car cable operated?
Old 09-13-2016, 06:13 PM   #23
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
Old 09-14-2016, 08:26 AM   #24
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
not sure about all that. I always keep in neutral and keep the parking brake on.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 09-14-2016, 08:30 AM   #25
gw6211
gw6211's Avatar
Drives: 2016 2SS
oh crap, guess i shouldnt have parked my car over that camp fire the other day, hope i didnt mess it up....
gw6211 is offline   Reply With Quote
Old 09-14-2016, 08:38 AM   #26
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I usually have it 2nd....maybe 3rd...could be 4th for all I know. Never have put a manual car in reverse.
Had 4 of them over 10 years of driving, a couple 100,000 miles, just left it in gear, it didn't matter and never an issue.
Thats a bad idea. You want the car in 1st or Reverse because if for some reason the car was trying to move it would also have to spin the engine over with it. So if you are putting the car in 2nd 3rd 4th or any higher gear you are only giving the wheels a smaller mechanical advantage to have to over come.
Think of it this way. If a person was pushing the car in first gear they would also have to push with enough force to spin the engine over. If the car is in 6th the engine wouldn't need to complete near as many revolutions to travel the same distance. So to get a car to roll when left in 6th gear, it would require a lot less force than if the car was in 1st gear.
Old 09-14-2016, 09:19 AM   #27
jlagman
jlagman's Avatar
I've heard that the rationale behind parking in 2nd is that if the parking brake fails, it's now the gear holding the car in place and they will be under stress. It will be a lot easier to temporarily lose 2nd than it will be to lose 1st.
Shrug
Old 09-14-2016, 09:38 AM   #28
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Shrug
Seems like a silly idea considering if the car has better holding ability in first gear. Say you put it in 2nd to save 1st gear but because the car isn't held as well it rolls away and is crashed. Some good that pristine 1st gear does you now.
