#15 | |
![]() Drives: HyperBlue 2SS 6M NPP MRC Nav Join Date: Dec 2015
2016 HyperBlue 2SS 6M NPP MRC Nav
#16 |
![]() ![]() Drives: 2021 300 Join Date: Jan 2015
Race gas is for race cars, period! Street cars usually have static compression ratios of between 8:1 and upwards of 11:1, and usually in the 9:1 and 10:1 area on most performance "street" engines. The problem running race gas is that if you don't have the compression to compress the fuel and air enough, you'll actually run SLOWER! I see this happen all of the time at the race track where during the Wednesday night drags, people with bone stock cars will go fuel-up with 110 or 114 octane race gas and wonder why they aren't running as quick, or as fast, as usual.
Contrary to popular belief, the more octane in gas, the COOLER and SLOWER the burn is, and more importantly, the more compression is required to get that fuel to release its energy. What happens to regular gas if you have too much compression or too much timing? You ping (detonate). How do you remedy that? You use fuel with a higher octane rating to get that uncontrolled burn back under control. For the full story- http://www.badasscars.com/index.cfm/...rod/prd427.htm |
#17 |
Retired from Car mfrs....
Chevron 87 for me, it's close and techron is the real deal......when I store the car , it gets 91 to reduce octane # loss.
#18 | |
![]() Drives: Impala Join Date: May 2015
Used to work for them back in the 90's. I know then that the closest Chevron stations to the Detroit area were in Kentucky. The gas was great enough for GM, Ford, and Dodge all 3 to have it trucked up from Kentucky in order to do their emissions testing. Also, most of the additives in other brands of gasoline are just Chevron Techron rebranded. They all buy their additives from Chevron. |
#19 |
Drives: '69 RS Pro Street Join Date: Feb 2016
#20 |
![]() Drives: 2016 Camaro 2SS Join Date: Jun 2016
Shell (93 Octane)
#21 |
![]() ![]() Drives: ^^^This Join Date: Nov 2015
Shell
#22 |
![]() ![]() Drives: Coupeless :( Join Date: Jan 2015
I typically use Shell, because that's the best station that's close to me. RaceTrac stations run rampant here, and there are no Exxon/Mobil stations or Chevron stations anywhere near me. There's also a ton of Wawa stations and 7-11 stations in the area.
If not Shell, my second best option around here is probably Costco. |
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Is Costco gas a top tier brand?
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers, Mamo Throttle Body Delivered: 08/15/2016 #TeamBeckyD |
#24 |
#25 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 21 Bronco Join Date: Jun 2012
BP or Shell
#26 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
91 Shell (because socal hates 93), and the station has a fuel truck dumping new fuel in daily.
#27 |
![]() Drives: 2016 Camaro 2SS Join Date: Jul 2016
I have filled up 6 times so no real trend to date but twice with 93 Citgo and it is cheaper. I might change stations as the pump takes forever (giving me the hunch that 93 is a slow seller).
#28 | |
![]() Drives: Hopefully 6th gen Camaro Join Date: May 2015
There is a Mobil gas station near me that probably has the highest gas prices in California. They charge $4.79 for a gallon of regular. Their gas prices never change. So the best gas prices for me (Top Tier) when figuring in proximity and price, it would be the local 76, Shell or Chevron station. Last edited by Bongos2U; 08-29-2016 at 11:14 PM. |
