#15 |
![]() Drives: 2022 Vivid Orange LT1-M6 Join Date: Dec 2015
M6
#16 | |
![]() Drives: 2016 Camaro SS Join Date: Apr 2016
Figured out a way to post a video. I just loaded it on You tube. Any constructive comments would be appreciated!!
https://youtu.be/dIuauW79PHc |
#17 |
#18 |
Anything else done to your car? 116 mph is good!
#19 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS M6, NPP Join Date: Apr 2016
Not bad, with a more practice I'm sure you can cut 12 flat and possibly even high 11's if you can cut a 1.7 - 1.8 60ft!
It just spun a bit longer but everything else looks good. You just need more seat time and I guarantee your 60 foot will drop! The MPH shows you have the power to get high 11's or very low 12's with a good DA. |
#20 |
![]() ![]() ![]() Drives: Want a gen 6 Join Date: Jan 2013
Impressive! When I saw that GN burnout (had not looked at the time slip yet) I thought you were going to get your ass handed to you, and it went the other way!
#21 |
#22 | |
#23 | |
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: a M6 LT1 ordered From Becky!!! Join Date: Jan 2010
Not an M6, you are thinking auto. It takes a bit of seat time to get consistant 2.0 60's on an SS M6 on stock tires. Good first DR run OP! Get any wheelhop on the DRs? Also be careful not to dump the launch, I have heard of broken axles. But not any broken diffs yet. Also when you get a good launch your mph might go down and so will your ET.
#25 |
![]() ![]() Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
Nobody has cut a 1.7 on an M6 yet. Fastest was a 1.86 on slicks. You probably are slower than street tires if you are only cleaning off Drag Radials, really need a healthy burnout to get them to stick. Otherwise they are worse off than those goodyears. I cut a 1.95 on street tire in my M6. I have mickey thompsons that I'm bringing with me when I hit the 1/4 this weekend. Hoping to hit 1.8 60ft and break 11s.
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
#26 | |
#27 |
![]() Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
After You Roll thru the water, Stop, and Do a Short Burnout, Approach the line slowly, When the TOP Bulb lights, Stop!! Collect Your Thoughts,THEN, When ready, Roll into the 2nd Bulb and Rev the Motor to 2K-3K (Time and Experience will tell you which is Right) and be READY, Leave on the LAST YELLOW, Hang on and have FUN!!!!! PS Looks like you have TO Much air in those DR's
#28 | |
Skip to the 1:58 mark in the video. The M6 Mustang driver cuts a 1.8 60 foot. He's a hell of a driver.. if the Mustang can do that, the Camaro can do that since the SS puts the power down much better than the Stang. Will def. take a lot of practice and hopefully not another clutch lol :(
