07-05-2016, 08:03 AM | #15 |
Drives: 2012 Camaro 2SS/RS Join Date: Dec 2015
I "bit the bullet" on the ecs kit and i couldnt be happier with the hp gains, but it is definitly not cheap IMHO. Have you thought about a zl1 setup? It would be a little easier on your wallet and since you just want to pep the car up a little bit it will give you plenty of that and more especially if you do cam and bolt ons
07-05-2016, 11:56 AM | #16 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
I've done the LSA conversion on my L99 -- heads,cam, etc...
You can check out my build thread to see -- I've done a lot to the car... Going on 11K miles since I've done the upgrads 590+ RWHP, 6 PSI boost with cam/heads/sc/headers... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
07-05-2016, 12:28 PM | #17 | |
Drives: 2014 SS Join Date: Apr 2015
That's the springs, cam, hardened pushrods, oil pump, every gasket, trunnion upgrade, timing chain and damper. There's no way a cam cost as much as a super charger. Parts alone for a blower range from 4500-9000 depending on if it's used or your power goals.
Toys:
2014 SS - TSP 235/239, CAI, LT's, 12.2 @ 115 ("SLOWLY" chipping away ET) 2000 Trans Am - Bolt-ons 13.0@110 (sold) 2009 YZF R1 - Race bike (road course)(totaled racing) 2008 YZF R6 - Race bike (road course)(still own) |
07-05-2016, 12:37 PM | #18 |
Drives: 2006 Z06 Join Date: Oct 2010
True, but that is only cam parts. What about a CAI, headers, PTB etc? That stuff adds up. If you add all that up, you can easily get to the $4k+ mark. Since most people only want to deal with a tune once, and a cam won't work great with a stock intake/manifolds, that should all be taken into account.
Nick
Corvette Z06 -1200ish rwhp |
07-05-2016, 01:30 PM | #19 | |
A cam install vs a blower install isn't remotely comparable for cost.
Toys:
07-05-2016, 02:05 PM | #20 |
100% agree. Just some people read that as $1500 for a cam, and think that is it. Heard it time and time again.
Nick
07-05-2016, 02:11 PM | #21 |
07-05-2016, 02:18 PM | #22 |
And any car adding power should be looking at doing things like bushings, axles, etc. So take into account a full build.
Like I said, starting from ground up is a great way to build a car. Get some good wheel/tires, brakes, suspension, then when you have more money later, add the power.
Nick
07-05-2016, 02:24 PM | #23 | |
Drives: camaro ss\rs Join Date: Jun 2014
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
07-05-2016, 02:25 PM | #24 | |
I have axles and CF driveshaft after I added the power.. It's always something... ;o)
747 RWHP 794 RWTQ
07-05-2016, 05:11 PM | #25 | |
Drives: 2010 2SS LS3 Join Date: Jun 2016
07-05-2016, 05:32 PM | #26 |
Anti wheel hop kit.
07-05-2016, 06:02 PM | #27 |
Tires should be #1 thing IMO depending what you have on there.
Nick
07-05-2016, 06:06 PM | #28 | |
I have the Brian Tooley stg 3 blower cam- https://youtu.be/cqJWMX-5lA0 https://youtu.be/3lKAyBx-s6o |
