Old 06-27-2016, 04:56 PM   #15
david borla
david borla's Avatar
Drives: Ford GT
Originally Posted by Tazz3069 View Post
David or Lisa or Forum member. Please help me understand AFM. I want to order a system and not sure which kit to order. If this is deleted, will I get a CEL? What is the main purpose of the AFM? Why two sets of Cats? I need help understanding so I can purchase the right system for my car.
I'm going to start with the conclusion of this post.
Our rear sections/axle backs install BEHIND THE FACTORY AFM VALVES. So, you do not need to purchase additional AFM valves with The Borla Rear Sections.
As a result, I recommend you start with one of our rear sections and then decide if you want to add a mid-pipe/X-pipe after that because AFM valves are only an issue with the mid-pipes/X-pipes that are added to our rear section to make a complete Cat-back.
For starters, do you have a manual or automatic transmission? I ask because there is no AFM with a manual transmission on these cars. At least the 2016 models.
AFM stands for "Active Fuel Management" which basically shuts off 4 of the 8 cylinders at cruise. This dramatically changes the sound, meaning an active exhaust system (with valves) is necessary.
Some enthusiasts disable AFM altogether (which is what I would do) and those Camaro owners do not require AFM valves. Others have a manual transmission and those do not need AFM valves either. Others are willing to tolerate the sound issues caused by AFM.
But, for those of you who have an automatic, want to retain AFM and don't want to deal with the sound issues, it's critical to have AFM valves.
With all of this said, our rear sections/axle backs install BEHIND THE FACTORY AFM VALVES. So, you do not need to ourchase additional AFM valves with The Borla Rear Sections.
As a result, I recommend you start with one of our rear sections and then decide if you want to add a mid-pipe/X-pipe after that.
david borla is offline   Reply With Quote
Old 06-27-2016, 05:13 PM   #16
Tazz3069
Tazz3069's Avatar
David
Thank you. I have an automatic. i will start with the rear section first then go from there. So If I order a kit without the AFM, is there a plug or something so the car does not throw a CEL?
2016 Camaro 2SS "Black Widow"
Tazz3069 is offline   Reply With Quote
Old 06-27-2016, 05:21 PM   #17
david borla
Drives: Ford GT
David
With the rear sections it's a moot point because the factory AFM valves remain in place.
If you order a midpipe/x-pipe with AFM valves for an automatic it will NOT throw a CEL.
If you order a midpipe/x-pipe without AFM valves for an automatic it will throw a CEL unless you disable AFM altogether. There's a company called Range Technology that sells an AFM delete device.
Old 06-27-2016, 05:27 PM   #18
Tazz3069
Tazz3069's Avatar
Awesome thank you
Old 06-27-2016, 11:05 PM   #19
raptor5244
Drives: 2022 CT4-V Blackwing
The automotive aftermarket is a multi-billion dollar industry and exhaust upgrades are one of the top 5 modifications. Hundreds of thousand of enthusiasts take off perfectly good exhaust systems every year and replace them with something that enhances the sound, look and performance of their vehicle(s)
It's mostly about personalization. Some enthusiasts want their Camaro to look, sound and perform different/better than others. Durability is a benefit important to many as well.
Here's what you get with Borla:
Sound - Sounds distinctly different from stock. Many exhaust notes to choose from, all much different from stock. Find the sound that fits your driving style. How do you want to be heard (outside the vehicle)? What do you want to hear when you drive (inside the vehicle)? Etc. The sound profile of a car changes the entire driving experience. Change the exhaust and it's like driving an entirely different car.
Power - Increase in horsepower as well as torque over stock across the entire RPM range. Even more potential to make power over the stock exhaust when adding other performance modifications like a cold air intake and/or chip/reflash etc.
Looks/Appearance - Looks distinctly different from stock
Durability - Million mile warranty on labor/material non-moving parts (valves have a separate warranty). Will never rust, can be cleaned/polished to a chrome-like finish over and over again.
In a nutshell, with a Borla system your Camaro will sound better, perform better, look better and be more durable. All in a way that fits your personality and driving style.
Anyhow, hope this answers your question. If not, let me know.
Cheers!
Thanks for the response.
2019 Tesla Model 3
2022 CT4-V Blackwing - M6
Old 06-28-2016, 11:51 AM   #20
Lisa@Borla
Lisa@Borla's Avatar
Drives: -
Hey guys!
Attached is our Product Selection Guide for the 2016 Camaro SS. This shows exactly what we are/will be offering.
Video = https://youtu.be/1o0HzNx8JqM
https://www.borla.com/chevy-2016-cam...haust-systems/
If you have any questions, please feel free to reach out to us at 1-877-462-6752 (Monday-Friday 7:30am-4pm PST).
Lisa@Borla is offline   Reply With Quote
Old 06-28-2016, 04:38 PM   #21
Razzaa
Razzaa's Avatar
The catback system is tempting!! I called my Local Mopac store and they want $2100 + tax!!!
Razzaa is offline   Reply With Quote
borla, borla exhaust, borla performance industries, exhaust, exhaust systems
