Old 07-05-2016, 04:49 AM   #15
LesserO2Evils
GM repeat offender...
Drives: 16 2SS
I dont ever hear it as much as I FEEL it in my car. I am super smooth on the throttle while cruising, and the constant 4-> 8 transition drives me crazy.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15
INCOMING: ‘22 ZL1, Satin Steel. A10. PDR.
Ordered: 03/02/22.
LesserO2Evils is offline   Reply With Quote
Old 07-05-2016, 04:28 PM   #16
jimmypop13
Drives: 2016 camaro ss
I couldn't hear anything in the video however my first exhaust had a chirp/squeak during the v8/v4 transition that came from the afm valves. They replaced the whole exhaust due to the NPP rattle. The new exhaust never chirped
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 07-08-2016, 09:15 PM   #17
ReFLeX135
ReFLeX135's Avatar
Drives: 2017 Camaro 1SS
I've compiled a video that catches all of the chirps/screeches/grinding much better. I think it's much more clear. Currently the car's at the dealership but I haven't heard anything back yet.
Getting up to speed and coasting, no shift = screech
Manually downshifting from 4th to 3rd to 2nd to 1st = screech/grind
In manual mode, no shift, and applying throttle from a lower speed = grinding
Hyper Blue | A8 | NPP Dual Mode Exhaust
ReFLeX135 is offline   Reply With Quote
Old 07-08-2016, 11:28 PM   #18
raptor5244
Drives: 2022 CT4-V Blackwing
Well, you should be able to rule out the AFM valves by just switching to manual mode. AFM does not engage when the trans is in manual mode. Furthermore, you could bring up the page on the dash that shows the v4/v8 display and see if the noise corresponds with the mode change.
2019 Tesla Model 3
2022 CT4-V Blackwing - M6
Old 07-09-2016, 01:22 AM   #19
jimmypop13
AFM does engage exactly once in manual mode. Once you switch gears after it comes on, it won't come back on at all until you're back to auto
Old 07-09-2016, 04:15 PM   #20
ReFLeX135
ReFLeX135's Avatar
Yeah in my original video I had the v4/v8 screen on. It seems to happen when it switches. This would be the first two screeches in the newest video, where it seems no shifting occurs. Manual mode shifting I did twice, so that wouldn't be the AFM for sure. I just really hope they don't tell me it's normal..
Old 07-09-2016, 11:00 PM   #21
raptor5244
For what it's worth I don't hear anything or feel anything when transitioning from v4 to v8 mode. The only way I know is by looking at the v4/v8 mode on the dash.
If it is the valves making the noise you can test it. There is a separate fuse that controls the AFM valves. You can pull it and drive. The car will still switch to AFM mode but the valves obviously won't close. However, be aware that when you are in v4 mode with the AFM valves closed the exhaust will sound bad, which is why we need them. Furthermore, unlike the fuse for the rear NPP valves, pulling the AFM NPP fuse will cause a CEL.
Has the dealer performed the TSB that calls for them to spray dry slide lubricant into the valve assemblies?
2019 Tesla Model 3
Old 07-11-2016, 04:00 AM   #22
LesserO2Evils
Drives: 16 2SS
Oh....WOW!!!! Yeah, I have non of that. Sure hope I dont, either. Im sorry bud...
Ordered: 03/02/22.
Old 07-22-2016, 04:49 PM   #23
ReFLeX135
ReFLeX135's Avatar
Just an update. The dealer said all of my transmission problems and noises, AFM/exhaust squeaks and screeches, are normal. They drove other 16 Camaros that had the same problems, which are "by design"...
Old 10-31-2017, 10:29 AM   #24
Wonkymom
Wonkymom's Avatar
When mine goes from V4 to V8 especially slow speeds on slight inclines I hear this annoying almost backfire “poof” sound - anyone else?? Or is that normal (dealership thinks so of course)
Wonkymom is offline   Reply With Quote
Old 11-01-2017, 09:29 PM   #25
JaxChris
Automatic transmission? That sound is the forward AFM exhaust valves (under your front seats) popping open. If it were a cylinder activation issue, you would hear the noise through the top of the dash because the rear cylinders are the ones that turn on and off (against the firewall). The open of this thread, his first video sounded very much like those valves activating. In his second video he didn't show a good DIC screen to contribute to what could be happening and it sounded like a squeak with headphones on, so it could've been a steering rack noise because it happened coming out of a turn both times.
Old 11-02-2017, 07:34 AM   #26
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
My car has the same scraping sound transitioning from V8 to V4. In mine, it’s definitley the afm valves causing the noise.
Old 08-19-2019, 05:32 PM   #27
cskipgo
cskipgo's Avatar
Drives: 2019 2SS A10 Shadow Gray
Any updates? Did everyone get theirs fixed, or silenced at least?
Having the same issue with my 2019.
cskipgo is offline   Reply With Quote
Old 10-09-2019, 01:50 PM   #28
ws2186
Drives: 1968 Camaro
Im curious what can be done also. Mine sounds like a bad exhaust leak whenever its in V4 mode
ws2186 is offline   Reply With Quote
