Old 06-07-2016, 09:00 AM   #15
samman11
Drives: 2011 Camaro SS Convertible
I have been told by several other muscle car owners to NOT USE any gas for a V8 engine that has ETHANOL in it. I see in the picture that all of the choices contain "less than 10% Ethanol. Therefore, I seek out gas stations that clearly advertise NO ETHANOL. Near me, I have found that FASTRAC gas stations have this option in their 91 Octane choice. I wish they had the 93, but I don't believe that between 91 and 93 that I would notice much difference in power.
samman11 is offline   Reply With Quote
Old 06-07-2016, 09:01 AM   #16
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
Not easy to find anything with no ethanol. It doesn't exist here.
POWERFREAK is offline   Reply With Quote
Old 06-07-2016, 09:08 AM   #17
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
Originally Posted by Ccl412 View Post
About every third tank or do I fill up with premium unleaded that has no ethenal it suppose to be good for the system I reall notice it when I run it through the bike
Yeah, my Connie LOVES the real stuff!
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
http://www.camaro5.com/forums/picture.php?albumid=17325&pictureid=134228
sherob is offline   Reply With Quote
Old 06-07-2016, 09:09 AM   #18
sherob
sherob's Avatar
http://www.pure-gas.org/index.jsp?stateprov=NY
Old 06-07-2016, 02:41 PM   #19
POWERFREAK
I.AM.
POWERFREAK's Avatar
Originally Posted by sherob View Post
Thanks, but NY is big...I've never even heard of 90% of the towns on that list, none are anywhere near me.
Old 06-07-2016, 02:55 PM   #20
sherob
sherob's Avatar
I understand... I'm from Texas.
Old 06-07-2016, 08:25 PM   #21
OrangeVert
"Catharine"
OrangeVert's Avatar
Drives: '11 2SS/RS LS-3 IOM/IO vert
Originally Posted by Spec View Post
Man... you can't tell me you don't get a gulp full of mixed gas when pumping that 93. Last guy could have filled up a lawnmower, then you ride up taking in some of that...
Good point, Spec. Bring your own gas can and put some in that first to ensure you're getting full 93. Just did the fuse pull again after 3 years and OMG!
OrangeVert is offline   Reply With Quote
Old 06-08-2016, 06:47 AM   #22
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Worked at a service station in HS. The tanker trucks have a compartment filled with Lowest Octane and compartment filled with Highest Octane ... the gas pump automatically blends the two when dispensing the middle grades.
The amount of residual fuel in the pumps hose from a previous customer would have no noticeable affect on the octane value for the next customer in line when they fill up their tank. The internal diameter of the pump fill hose is much less then it appears; for safety reasons, there is a very thick multi layer wall and steel grounding cables - anti snap cables that runs from the pump to the nozzle. Had a customer try to drive off before the nozzle was removed from their car's filler neck and the hose was strong enough to stop the car ... until the driver stomped on the gas pedal. This was back when the car gas tanks and filler pipes were both made of steel and the filler pipe was firmly attached to the car.
On more than one occasion, after the car's tank is filled, had customers get out and shut off the pump, then press the nozzle handle, raise and lower the hose to let the residual fuel drip out to their car's tank, moving the nozzle out a ways they discover not much in there to bother with.
There are many stories about water getting in the car's tank after fill-up making a bad mix or causing cars to stall ...
the way the station tanks are designed there is a pipe that sticks up from the bottom of the tank which then runs to the gas pump. Any water in the gas sinks to the bottom of the tank. The station tanks do have water accumulate in the bottom of the tank, however, it is a relatively small quantity and extremely unlikely it would build up enough to reach the height of the intake pipe running to the pump. The station staff and tanker driver are suppose to put a chemical paste on the measuring stick and lower that in the station's tanks after each fuel truck delivery to monitor the water level as a precaution, at the same time they measure to verify quantity of fuel delivered (the white paste turns a dark color when water is present and detects exactly how thick the water layer is at the bottom of the tank.).
Here is a Nine-Grade pump pic I posted in the other related thread:
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 06-08-2016, 07:26 AM   #23
BlkCamaroVert
BlkCamaroVert's Avatar
Drives: '11 2SS/RS L99 Vert IO Interior
There's plenty of marinas selling it in my area. Do they only sell to the boats? I'm sure the price would be higher.
BlkCamaroVert is offline   Reply With Quote
Old 06-08-2016, 07:29 AM   #24
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
No E85 button. Move on to the real octane
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
Shawno72 is offline   Reply With Quote
Old 06-08-2016, 08:53 AM   #25
Steve Dallas
Commits weekly crime
Steve Dallas's Avatar
Drives: 2017 Camaro 1LT
The question is...is it top tier gas.
I don't go to stations that don't use top-tier. I would suspect this place you're at isn't...I could be wrong though.
I have never used anything but premium on my SS, my Z51 or my Z06. It's nice that it's 93 out east, however we only get up to 91 or 92 out here in Washington State.
2017 Camaro 1LT - Blue Barchetta IV
I fire up the willing engine, responding with a roar. Tires spitting gravel I commit my weekly crime.
Steve Dallas is offline   Reply With Quote
Old 06-08-2016, 09:16 AM   #26
Royal Tiger
I try and use only 93. Not many options for getting away from E10 unfortunately.
Old 06-08-2016, 10:12 AM   #27
sherob
sherob's Avatar
Boats sit for longer periods of time, so they HATE ethanol in their fuel.
Old 06-08-2016, 12:02 PM   #28
ron123
ron123's Avatar
Drives: 2014 2SS/RS
In some regions, big name gas stations use the same gas station distribution facility that also delivers to the small independents. Truck drivers at the station I worked at in HS told me often times it was the exact same fuel being delivered to the name brands and independents. One tanker driver said that when he delivered to Mobil stations they dumped in a small container of the "detergent" before leaving the terminal and that magically turned it in to Mobil Detergent Gasoline by the time he arrived at Mobil stations, diluted in to 4,000 gallons of fuel per compartment - this was back in the early 70's ;-)
Ron
