Old 07-24-2016, 10:02 AM   #15
carguy83
carguy83's Avatar
Drives: 2009 Pontiac SV6, 2016 Camaro 2LTRS
Hey there, I also have the same model as you..2016 VS RS auto. Yesterday I started the car and had nothing except the current gear I was in lit up red. No other gears were visible until I put the shifter into a different gear. I turned off the car and restarted it and all was normal: every gear lit up in white, and current gear in red. Seems like a little electronic glitch
carguy83 is offline   Reply With Quote
Old 07-24-2016, 10:53 AM   #16
nbryant
nbryant's Avatar
Drives: 2016 2SS Red Hot
Have had the exact same thing once in my SS.
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter
nbryant is offline   Reply With Quote
Old 02-22-2020, 11:06 PM   #17
WhiteDevil
WhiteDevil's Avatar
Drives: 2017 ZL1 A10
Bump, anyone else had this issue recently?
WhiteDevil is offline   Reply With Quote
Old 08-22-2020, 03:26 PM   #18
Syndaar
Syndaar's Avatar
Drives: 2017 V6 RS A8
Bumping again to reply to WhiteDevil. I had this issue with the lights only showing the Red light for which gear I was currently in on my 2017 V6 RS two times so far since May, 2020. Just had the 'Shift to Park' issue resolved as well by replacing part #84588250, but the issue with the lights happened the same day I got the car back.
If anyone has any other info on this it would be greatly appreciated.
Syndaar is offline   Reply With Quote
Old 08-30-2020, 01:37 PM   #19
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
Hmmm...by any chance, does it only happen after remote-starting the car?
If so, it may be a start-up sequence glitch. Try waking up the electronics first by unlocking with the fob first, and then lock and remote start.
Works for other electronics glitches in the Camaro.
Good luck!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 08-30-2020, 02:25 PM   #20
Syndaar
Syndaar's Avatar
It’s entirely possible that is what caused it. But I usually hit unlock, lock, then start it up to fix all the infotainment UI glitches. Thanks for the suggestion. It hasn’t happened again at this point thankfully.
Old 07-23-2021, 12:49 PM   #21
Nated421
Nated421's Avatar
Drives: 2017 50th Anniversary SS Camaro
Bump my lights don’t come on no matter what 17ss with 34k just happened a few thousand miles ago. Bought the car new , never happened until now and it isn’t came on in months!
Nated421 is offline   Reply With Quote
Old 07-23-2021, 03:32 PM   #22
Hm, time to visit the dealership... or, if you want to tackle this yourself (I guess your bumper-to-bumper has long expired anyway), the part number for the shift indicator is 84373425. That is the most likely culprit, I think.
Old 07-24-2021, 05:25 AM   #23
Nated421
Nated421's Avatar
Thanks buddy! Not something I would like to have to replace, however it’s only 55$ @thatgmpartsguy so not to upset
