#15 |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
This is an AMAZING kit. Works perfectly. As Im sure is already stated(didnt read all posts), the included brush is crap. Ive used this kit before and its the ONLY WAY to do calipers. I did all 4 calipers with 4 coats and STILL had nearly 1/4 can left.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
#16 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
I might actually end up using it and see how long it lasts. Powder coating is a PIA since you need to bleed the brakes, remove everything and send them out. I just don't have the patience or time right now to deal with all of that and can powder coat over the winter when I won't be driving the car.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge ![]() 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
#17 |
![]() Drives: 2016 Camaro SS Join Date: Apr 2016
There is another option. There's a local guy that masks it all off and airbrushes the calipers with hi temp paint of your color choice. Adds decals and then clears. It's not cheap but cheaper and easier than powder coating and looks better than G2.
Might be worth checking around your area if you're looking for a higher quality finish. Example:
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad 91 Miata 1.8 Feal Wilwood Track Car 1morproject |
#18 |
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
You can get away with mixing up half the epoxy and still get the job done with a good brush. It sprays very well too.
#19 |
![]() Drives: 17' Camaro 2SS 16' Jeep GC SRT Join Date: Aug 2016
How well did you get the back?
#20 |
Bueller?
#21 |
![]() Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT Join Date: Sep 2016
Hey, just a follow up, planning on doing this, but noticed the stickers on Amazon have ship date about 1 mo. out, has anyone recently bought the stickers and gotten them sooner? Would suck to have to wait a month. . .
#22 | |
#23 |
will those white brembo stickers stick really well to the caliper? I was thinking u should put the stickers on before the paint does dry so it helps stay on.
#24 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Mine have stayed on without issue. The paint was dry before I put them on.
#25 |
3m adhesion promoter will solve the problem
