05-07-2016, 04:15 AM | #15 |
Drives: 2013 Camaro SS LS3 Join Date: Jun 2015
Wow that's crazy, I never knew about that. I'm going to figure out why my fuel pump isn't priming, and if it still doesn't run that's going to be next on my list. HopefullyiI don't have to pay the dealer to do that
05-07-2016, 07:46 AM | #16 |
Okay so I checked the schrader valve and fuel shot out, so I'm definitely getting fuel pressure.
05-07-2016, 08:39 AM | #17 |
Drives: 2011 2SS/RS Vert Join Date: Jul 2015
I just installed a different engine in my theft recovery 2011 SS ( Engine Tran. taken)and took it to the dealer on trailer to have all the modules set up. Took the car home and I got a code of P0315 for crankshaft position relearn. The car would not run more then 1-2 seconds and shut off. Talked to the mechanic at the dealer and he said the crankshaft relearn would not cause the problem but will have to bring it back for them to clear the P0315.
I did not have the intake box hooked up the throttle body because only had the top half of the intake box with the Mass Air flow sensor sitting on top the engine. Got the complete intake box and installed it and car started right up and did not shut down anymore but ran rough because of the P0315 code. If you do not have the Mass Air Flow Sensor in the air stream going into the throttle body the ECM senses no air and shuts the engine down so there is no damage Hope this helps you out. |
05-07-2016, 09:50 AM | #18 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Also something to double check is that all of your grounds are connected you would be surprised one ground with a little tiny wire can screw the whole system up.
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
05-07-2016, 01:13 PM | #19 | |
05-07-2016, 01:14 PM | #20 |
I'm going to check those again those grounds are a pain! I wish they didn't make them so small to wwhere it's nearlyiimpossible to find them
05-07-2016, 09:32 PM | #21 | |
05-07-2016, 09:58 PM | #22 |
Drives: 2006 Z06 Join Date: Oct 2010
Uhh...
Maf sensor has to have air flowing across it, and that is what the car uses to determine fuel. If it isn't in the intake, it will detect zero air, and then spray zero fuel. So of course it needs to be in the intake stream.
Nick
Corvette Z06 -1200ish rwhp |
05-08-2016, 07:25 AM | #23 | |
Not true I have run a lot different cars without the MAF sensor in the intake airflow they run but rough. Ever manufacture is different |
05-08-2016, 07:26 AM | #24 |
Tags |
cam tune, new engine, problems, won't start |
