Old 04-29-2016, 08:57 AM   #15
Modshack
Modshack's Avatar
Drives: 2SS, Hyper Blue
Originally Posted by Tim Adams View Post
No it is not. It is #15. I am holding it in my hand right now.
Lets start again as you're missing this... YES it is a 15 amp fuse. (15 is the amperage capacity)
It is in fuse slot #51 (see the fuse guide in your manual or on the fuse box lid)
There are other 15 amp fuses in the fuse box. You don't just pull one that says 15!
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav
Modshack is offline   Reply With Quote
Old 04-29-2016, 09:29 AM   #16
Tim Adams
Tim Adams's Avatar
Drives: 2020 Elkhart Lake Blue 1LT Z51 C8
Ah ha!! My mistake.
Ordered-Hyper Blue 1SS, A8, NPP, 56W wheels Built 1/20/16
Delivered 2/12/16!!
Sold 9/17/19 :(
2020 C8 ordered!!
"The greatest sound in the world is a Rolls Royce Merlin over 100 inches"
www.timadamsphotography.com
Tim Adams is offline   Reply With Quote
Old 04-29-2016, 01:01 PM   #17
jimmypop13
Drives: 2016 camaro ss
Originally Posted by forzasteve View Post
I don't have a 2016 Camaro. A local owner tells me that with the factory NPP option he can force the valves open using two buttons, regardless of which driver mode the car is in.
There seems to be different opinions shared here. On one hand people say that to force the valves always open you pull the fuse or have a device to control that fuse circuit to override the vehicle controls. Then their are others who say they use the driver mode controls and user options to accomplish the same thing.
Steve
That local owner is definitely incorrect though. No way to force the valves open without pulling the fuse or making one of these controllers.
Here is an excellent write up on functionality of the system. Ours is identical(except fuse #'s): http://www.corvetteforum.com/forums/...ck-result.html
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 04-29-2016, 05:53 PM   #18
ender2664
Drives: 2016 2SS
You find someone to help you with your switch?
ender2664 is offline   Reply With Quote
Old 05-06-2016, 08:20 AM   #19
1hevy_chevy
1hevy_chevy's Avatar
Drives: Nightfall Gray 2016 6M 2SS
Hurry up!!!! I want
1hevy_chevy is offline   Reply With Quote
Old 05-09-2016, 03:41 AM   #20
Grim
Grim's Avatar
Drives: 2017 Camaro ZL1
Also remember there are 2 vales on the A8. 1 is for the AFM and the second set is for the NPP.
Grim is offline   Reply With Quote
Old 05-09-2016, 03:24 PM   #21
JFM-jr
JFM-jr's Avatar
yes
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 05-13-2016, 02:23 PM   #22
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Man I've been looking for this thing forever and finally found it. That damn bug with Drive Mode settings vanishing makes this thing a great find for someone with headers. I'm sending a PM now and would test it for you. Otherwise I'll buy one if it works.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 05-14-2016, 03:00 AM   #23
JFM-jr
JFM-jr's Avatar
I can verify it functions in our 6th gen. Sit tight I will have a write up with pics very shortly.
Rotofab
11.0@124.9
Old 06-03-2016, 10:32 AM   #24
sixbrx
Drives: 1SS Hyper Blue
Is there a way of having it switched on/off with the ignition? I see it recommended to use F30 for the power (windshield wipers) but that appears to be unswitched (light stays on without ignition) as were all the other fuses I tried at random.
So: anyone know where's a good place to tap switched 12V power in the engine bay?
sixbrx is offline   Reply With Quote
Old 06-03-2016, 08:24 PM   #25
forzasteve
forzasteve's Avatar
Drives: Love any sports cars
I thought the Windshield Wipers were switched to the ignition. When you turn off the ignition the wipers no longer function ... is that right? If the fuse location is still hot then they must be switching that circuit downstream of the fuse.
Use a voltmeter. Attach one lead to ground on the car. With the other lead, probe the fuses (there is are two small contact points on the top of the fuse). You can test if the circuit is hot by simply touching the voltmeter probe to the test points in the top of the fuse.
Let us know which fuse you may find that is switched to the ignition. Note, you may have to wait 10 minutes or so after switching off the ignition before testing to allow the car's ECU to time out. Many circuits are kept active for several minutes after switching off the ignition.
Steve
forzasteve is offline   Reply With Quote
Old 06-03-2016, 08:33 PM   #26
forzasteve
forzasteve's Avatar
Announcing Support for Gen6 Camaro
The Forza Controller Model C1 is now available for use on the Gen6 Camaro.
The Model C1 provides two operational modes:
  1. Normal mode ... control of the bypass valves via the car's ECU
  2. Always Open mode ... forces bypass valves open, removing control by the car's ECU
This model controller was originally only supported on the Gen5 Camaro with NPP and now it is supported on the Gen6 ... and on Corvette C7 as well.
You can read more here ... http://www.forzacomponenti.com/exhau...troller_c.html
Thanks to those people here that helped with testing. I look forward to being able provide this level of control for the Gen6 owners now.
Regards,
Steve
Old 06-04-2016, 09:32 AM   #27
1hevy_chevy
Regards,
Steve
Hey Steve! Quick note on your link where it shows the simple instructions it states that on the gen6 the device needs to be installed near the fuse block in the rear of the car, however if I am not mistaken the fuse for our NPP is in under the hood #51
Rotofab CAI, Mishimoto Catch Can. Other than that Stocky-McGee for now
Old 06-09-2016, 12:17 PM   #28
sixbrx
Use F43
Steve - thanks for the tips and sorry for the delay, I'm just back in town.
I found that F43 (AFM valves) makes a good switched power source. The wipers fuse is always powered so as you say they must be switched elsewhere.
