#15 |
![]() Drives: 2015 Porsche BGTS, 2016 2SS Join Date: Oct 2013
It takes longer to wake up all 455 horses...... Just kidding.
#16 |
![]() Drives: 2016 C7 conv 7 speed. Black/black Join Date: Jul 2014
If you had a key ignition I would imagine you could let it build up pressure then start it. I do this with my 502 and let the fuel pump prime the system then start it. My SS does take a few cranks to start. It doesn't matter if the car sat for a day or week it still doesn't fire on the first crank.
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
#18 |
So there's no electric fuel pump ?
#19 |
![]() Drives: 2016 SS Join Date: Mar 2016
Anyone know if it's the same in the C7 Vettes?
#20 |
Retired from Car mfrs....
Its totally the same
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
You have to remember the 3.6 and the 6.2 LT1 are 2 totally different engines. I have that same 3.6 DI engine in my SRX, and yes it starts much quicker, but again the pressure needed is much greater is a large engine like the LT1. My LT1 in my SS takes a few cranks as well, cold or warm, doesn't matter how long it sits.
#22 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
there is an electric fuel pump in the tank but the high pressure fuel pump is mechanically operated by a lobe on the cam.
#23 | |
LT-Won!
Drives: USB ISF 5.0 Join Date: Mar 2016
(direct injection) At end of #6 |
#24 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
mine always rolls over a few secs before lighting
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
#25 | |
![]() Drives: something faster than you Join Date: Aug 2010
