#15 |
Try my method described in https://www.camaro6.com/forums/showp...7&postcount=20 that I have used with two different Blackvue dashcams. Easy install, even total amateur yours truly could pull it off in about two houirs, almost invisible from inside the car, wiring in the trunk looks "almost OEM", heh, and most importantly, the setup has been working 100% reliably since April 2018.
#16 |
![]() Drives: 2019 Camaro 2SS Orange Crush Join Date: Jan 2024
What did you guys end up using? i need constant 12v power for my dash cam
#17 | |
![]() Drives: Camaro ZL1 1LE M6 Join Date: Mar 2023
Looking for the same answer but have an additional question as well. Are we able to use the fuse box under the hood? If so, what 2 fuses do you all recommend to tap into?
ZL1 1LE
#18 |
Electrical Engineer
They describe their methods in the referenced thread: https://www.camaro6.com/forums/showt...7#post10254807
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 64k mi. @ Apr 2026 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
#19 | |
ZL1 1LE
#20 | |
![]() Drives: 2SS - Black Join Date: Oct 2009
Procharger D1X
Kinda fast, I guess |
