#15 |
![]() ![]() Drives: 2016 Corvette Z06 M6 Join Date: May 2009
Yup I know. Went thru the same thing with my ZL1s
2013 Dodge Viper #44/150 Launch Edition IG:@absoluthank
20/21 BC Forged Wheels : BC Coilovers: TA Aero |
#16 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Looks real good!
#17 |
![]() Drives: 2016 Camaro SS Join Date: Apr 2016
Looks really good.
How would you rate the quality of the spacers? I've done similar with the calipers in the past. I found some heat resistant Brembo stickers on Amazon and then used VHT caliper clear over the top. |
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Blk/Blk 2018 Sierra SLT Join Date: Dec 2006
Looks great! Will the spacers make any difference in handling?
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6 |
#19 |
Honestly I rate them high. I've run numerous eBay sets on my lifted trucks and they are hit and miss. I've also bought the custom billet ones from Motorsports Tech. These seem really nice.
#20 |
I wanted to take a slomo video so I had my coworker drive the car. Pretty cool!
http://youtu.be/G5JYuQaCKlQ
#21 |
SABIO
Ya buddy. That looks sweet.
That lowering kit is perfect. Its a performance kit as well. I bet on a track it will shine. $1900 up here in Canada
#22 |
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Looks soooo good. I'd love to do the same but am on hold due to MRC. I have spacers with longer lug bolts on my 335, and my daughter runs the studded type you bought on her G37 lowered on H&Rs.
I'd like to try spacers on the Camaro, but don't want the added unsprung weight of the type with studs on this car. I'd like to try the Adaptec 15mm with longer studs: https://www.motorsport-tech.com/adaptec/car/chevy_s Can't justify the expense of wheels/tires anytime soon. Rather put that money toward an SC fantasy and go +10mm on these stock wheels when the OE tires are done. |
#23 |
![]() Drives: Camaro 2SS A8 NPP Join Date: May 2015
Looks much better, congrats!
Mosaic Black 2SS A8 NPP
12.08@115 MPH |
#24 | |
#25 |
Did you measure before and after to see how close GM was on there drop specs. I like the 1.5 drop much better, but for most just closing the gap is much better then where GM started with the car.
#26 |
Is it normal to have to trim down the factory studs?
#27 |
![]() ![]() Drives: 2SS, Hyper Blue Join Date: Feb 2016
Not always. Some wheels have relief areas cast in between the lug holes. If not, or if this area is of limited depth , and the studs stick out beyond the spacer face then they would have to be trimmed to fit. A 25mm spacer would have likely not required that..
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav |
#28 |
If he ever decided to remove the spacers would those studs then need to be replaced?
