#15 |
You like it, get it!
I'm not in love with it, but it doesn't look bad at all.
JRE 750 HP package
Rag Top Rob |
#16 |
![]() Drives: '10 Camaro SS ---> '15 Mustang GT Join Date: Apr 2016
#17 |
![]() ![]() Drives: 2016 2SS Garnet Red Camaro Join Date: Aug 2015
I don't like it at all! A little over the top.
Ordered: 8/8/15, 2SS Garnet Red
Built: 10/14/15 Current: Took Delivery, 12/24/15 Added Procharger supercharger. ![]() |
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: too many Join Date: Jul 2013
I wouldn't do it..
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Love the one you're with Join Date: Sep 2009
Looks silly and ricer. Yours looks awesome and even if it doesn't, it looks like it has purpose.
#20 | |
![]() Drives: 2016 Camaro SS Join Date: Apr 2016
And your car looks great. I think the splitter would look pretty good on it and certainly set it even further apart from the others. |
#21 |
![]() Drives: 2016 Camaro 2SS Join Date: Nov 2015
#22 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS Join Date: Apr 2013
Seriously though, your car is extremely tastefully modded as it is. I know we all fight that inner urge to find something else to change, but don't give in. Save that money toward something better. Something like this is going to force you to be overly cautious with your car to avoid scraping it, which will in turn impact how much enjoyment you get out of the vehicle.
I've learned this the hard way myself. Some mods look cool, but aren't worth it when you have several hundred dollars worth of parts at risk of being easily damaged. It's like walking on eggshells. |
#23 |
![]() Drives: 2016 Black 2SS + NPP + MRC Join Date: Sep 2015
Thanks for an original answer. I have the front splitter but not the 6LE one and still haven't gotten info on where to get it if I did want it. Thanks though!
#24 | |
#25 |
Drives: 2016 Camaro 2SS White/White Join Date: Jan 2010
Looks like a piece of plastic just drilled onto the factory splitter.........maybe if it was an actual splitter it would be legit........
#26 |
Drives: 2016 Camaro 2SS Join Date: Jan 2016
Alrighty... lol. Lot of opinions in here (to each their own I agree) BUT not a lot of facts...
So, first of all you can get it here... http://6litereaterdesigns.com/store/...roducts_id=802 Second of all it is an actual AIR SPLITTER, unlike the OEM piece which is simply a FRONT GROUND EFFECT. The point is two fold... 1) It literally splits the air, causing a packing to happen at the front bumper (this is a good thing, helps direct air flow) and in doing so SPEEDS UP the air UNDERNEATH the car which is what causes additional DOWN FORCE (and on a car with an already "panned" underbelly it works even better than on most cars). 2) It PROTECTS that expensive bumper paint and front ground effect paint FROM scraping lol. It looks large like it will scrape but the way we designed it the clearance is the same as the factory lip. Of course if you extend it all the way forward (as it is adjustable) then you will lose a SMALL amount of clearance which simply means take a steep driveway at an angle BUT if you DO scrape it's made for it, it is textured ABS and it will protect the rest of the car. It also directs more air to the radiator and brakes and we have seen increased cooling on road tests. The "double chin" comments I completely understand, however, this has been a racing standard for a LONG time... a "ground effect" piece that hugs the bumper with an "air splitter" underneath it... ![]() ![]() ![]() ![]() ![]() Anyways... you get the idea lol. Again, to each their own, but it's extremely functional, protective, aids in cooling and IMHO overall badass looking lol!!! ![]() It will look even that much better once the splitter rods get here (had to custom order a set, supposed to be here tomorrow) !!!
#27 | |
Also we've been making them for about 8 years now. Started off developing them at CMJ Racing and track testing etc... We'd show wind results, track times, cooling effects, etc... and people still didn't "get it". Finally just had to make a silly video for people to understand it lol... I'll leave this here
#28 |
Appreciate your comments on your product. My problem with it is that kt looks have a large gap between the top of it and the bottom of the factory one. Is that just the camera angle? Not of the other cars you posted look like that. I believe that is way people are saying the comments they are.
