#15 |
![]() ![]() Drives: 2016 Camaro 2SS 6SP/Suby Legacy 6 Join Date: Oct 2015
Try driving in a C7. Now those seats suck, unless you are a stick!
TFPK40
Its Here! Finally came home on 3-31-16! Red Hot 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Silver Rally Stripes, NAV, Sunroof, 56W Split Spoke Wheels, Body color Hood vents, Body color Splash Guards and winter protection package. Ordered 1-28-16: 1100 2-11-2016 :2000 2-15-2016: 3000 TPW of 3/7...That went quick! ![]() 2-26-2016: 3400 Status TPW 3/7 3-5-2016 : 3800 3-8-2016 : 4300 3-11-2016 : 4B00 3-15-2016 : 4200 3-22-2016 : 4800 3-29-2016 : 6000! |
#16 |
![]() Drives: Z28 Join Date: Nov 2015
I too found the 2016 Camaro seats way too narrow. The 2SS leather seats kill my thigh. The 1SS seats are slightly more flexible. I am 6 ft 220 and the seats in my 1997 Z28 have bolsters that are low and comfortable. Chevy needs to get their act together on this. The Gen 6 cars are wider than my 97 Z28 so there should be room for a wider seat. I also sat in a 2016 Vette and you have to be a stick. Those seats suck too.
#17 |
![]() Drives: 2017 50th SS Convertible Join Date: Nov 2016
Now I know it's not just me, or that I somehow ended up with an oddball drivers seat. I started noticing the pressure from the left seat bolster against my left outer thigh soon after I picked it up. I don't recall feeling it on test drives though. Been wondering what the deal is ever since I got my car. I'm 5'7"/175, and average build. It's distracting to say the least. I'm hoping it will break in some and I'll have to play with different seat positions to see if that helps. Glad I found this thread and that it's not my imagination.
#18 | |
![]() ![]() ![]() ![]() ![]() Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms. |
#19 |
Good hearing from another 50th owner Homer! I'm coming up on 1200 miles. Sounds like break in will eventually happen.
#20 |
![]() ![]() Drives: 2017 ZL1 Join Date: Oct 2016
I have it too. If it makes you feel any better, its about 4x worse on the c7. You will get used to it though. Try changing the angle of the bottom section to be more level.
#21 | |
I used to be Dragoneye...
The seats are an improvement in both comfort and support to the 5th gen seats...10 hours straight, and I was perfectly comfortable. (Can't say that about my current Recaros...) |
#22 |
![]() Drives: 2017 2SS/M6 W/MRC & NPP Join Date: Nov 2016
Haven't noticed this on my 2SS or loaner 1LT, My old 370Z had this problem though to the point it was bruising my thigh. I just put a bunch of force on the bar to try and bend it, And readjusted the seat so I wouldn't be putting my fat on it.
I do wish the Camaro seats had just slightly more aggressive bolstering (Not as aggressive as the 370z's but just a little more) and adjustable lumbar support though. |
#23 |
The BEAST
Drives: '16 2SS, '89 Wife Join Date: May 2015
I wonder if the reason some are having problems with the left side bolstering on the legs is because the seats may not be perfectly centered with the steering wheel and pedals? I have no way of telling, but just a thought... I know that's what BMW did with the M2
#24 |
![]() Drives: 2022 Camaro LT1 Join Date: May 2016
I daily mine and the only issue I've had was my right knee smacking the hard plastic around the console when cornering in the twisties. Otherwise I've done multiple long distance trips and I drive a half hour each way to work every day with no other complaints. I'm 6ft, 195lbs myself.
I find it a lot more comfortable than my old 2013.
2022 Camaro LT1 6.2L, 10 Spd, Black/Black
*SOLD* 2016 Camaro 1LT V6, 6 Speed, Hyper Blue Metallic |
#25 |
![]() Drives: 99 M3, 04 STi, 16 2SS Join Date: Oct 2016
Alright, here's one for you guys. For those of you having this issue, do you use the dead pedal? My car is a 2SS auto and I feel like the dead pedal is not set in the ideal spot. For me, the ideal location for the dead pedal would be about 2 or 3 inches towards the passenger side, ie. it is most comfortable for me if just the edge of my foot is on the pedal. With my full foot on the pedal, I find it to be slightly uncomfortable. Perhaps this is contributing to your bolster complaints?
#26 |
![]() Drives: Blue Velvet 2SS, 8A, No Options Join Date: Nov 2016
another fat man agrees....
#27 |
![]() ![]() ![]() ![]() Drives: 2021 Shadow Gray 1LS Join Date: Oct 2011
Found the seat angle of the bottom cushion uncomfortable in my 5th Gen, and the seat back a little too narrow in the 6th Gen convertible I test drove.
My thought- I'm not going to be driving the car to California . I'm old and busted up. I'm happy to drive either one. |
#28 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
I find my seats very comfortable. I do have the lower part tilted in the direction that makes me angle backwards, sort of like I am about to blast off in a rocket. If you take the automatic seat and use the rear part of the vertical control and push it down it will "sink" the back part down which raises the thighs up in the air and sort of tilts you backwards. I'm not sure I explained it right but I had to do this and once I hit the sweet spot they are super comfy.
