#15 |
![]() Drives: Mercedes E350 Join Date: Feb 2016
I find it inexcusable and ridiculous that the Chevy engineers failed to create a system that readily accepts the Ipod. All my music is on Ipod/Itunes. I only buy new music on Itunes. If my Ipod isn't going to work in the Camaro, I will simply buy a different car. Period.
#16 | |
A Heartbeat Away.........
Drives: Not As Fast As I Would Like To Join Date: Mar 2016
BTW - thumb drives are the way to go. Verbatim has 32GB Nano USB drives that are hardly noticeable when plugged in.
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. |
#17 |
Can you build playlists and shuffle play within the playlists on the thumb drives?
#18 | |
But my 64 gb flash drive is in all the time built by CarPlayList. I have a couple of thousand songs on it. There is only a short wait for indexing and it works flawlessly. Even some of the songs have artwork even thoug my all did not address that. I suppose artwork can be embeded in the mp3. When my Ipods (both 16GB) are recognized it takes a long time before it really starts working. I think I have the direct Itunes interface almost completed. Of course Apple makes this hard. With the flash drive you scrifice nothing from the iPod except audio books. Any other way to play these without an iPod? I can do it with Google car play, but is is very awkward. I wonder if the Audible app supports bluetooth? Thought of another CarPlayList feature I will add to let you delete playlists and attached songs form the USB. I am enjoying this project. But going slow weekends and nights.
#19 | |
![]() Drives: 2017 2SS Join Date: Feb 2016
#20 |
^ Cool! I will try that. Thanks.
#21 |
![]() Drives: White 2SS 6MT Join Date: Sep 2015
I am super intrigued by this. I need to try it out.
I had a first generation iPod touch in my Infiniti and GTI that worked perfectly...doesn't work worth a dang in the new Camaro...So I went out and got a new iPod touch figuring it had to work better. Unfortunately, it is super slow, regularly lags out, Shuffle doesn't stay enabled and I get this popping / crackling noise through the audio pretty frequently. Sometimes if I unplug it and plug it back in things work better for a while, but it eventually starts degrading in quality and speed again. I need to try the flash drive approach. Worth a shot at least. Thanks for the info! |
#22 |
Thanks Fraxum for putting this info together. This appears to be WAY better than using the iPod.
![]() For what its worth, I haven't found a drive larger than 32GB that works with the Camaro though...tried about 5 different USB drives formatted in a variety of ways (FAT32, exFAT, NTFS) and none of the 64-128gb drives were recognized. All of the 32GB drives were though. Also, the manual says only .mp3, .wma, .ogg, and .wav files are supported, but my collection of M4A files were also recognized. Embedded album art works for most of my tracks (when embedded in the file) but it isn't working for others. At first glance, it looks like the unsupported artworks are in non-square resolutions. For example, the art shows up when it is stored as a 500 x 500 or 600 x 600 JPEG, but it does not appear to show up when in a more obscure resolution (the example for me that does not work is 713 x 659) I'll fiddle with this some more this evening. Getting this problem sorted out leaves me only two other things that are bugging me with this awesome car ![]() EDIT: I found a 64gb SD card + reader that works! Only when formatted as FAT32 (Not exFAT like the owners manual SAYS should work...) Last edited by alaskajoel; 04-26-2016 at 07:24 PM. Reason: Updated |
#23 | |
I have the app all working now but I have to work on the UI a bit to reduce clutter. The Camaro only wants Fat32 formatted drives. While CarPlayList can format USB drives I am testing to make sure it can do it with big USB drives. Windows cannot. Not sure if it will be able to do USB formatting on a Mac.
#24 | |
So far the app supports both types of Playlist files and directly extracts iTunes playlists so you don't have to export them. But you will need to turn on the xml interface in iTunes. Are there any other popular Windows apps for organizing your music?
#25 |
Any thoughts on using buttons instead of web like links?
My daughter thinks most people want buttons instead of links. I wonder. I may put some sort of button bar on it. Opinions? I do need to clean up the clutter either way. ![]()
"Democracy Dies in Darkness" Last edited by Fraxum; 05-01-2016 at 11:47 AM. |
#26 |
Links are perfectly fine IMO. I've been using musicbee after ditching the ipod and iTunes. It allows you to download the proper album art super easy and build Playlists. I like the GUI and popup notifications better than iTunes too.
#27 |
Cool! I will look into it for V2. I bet it is easier to work with than iTunes.
#28 |
Took my daughter's advice to heart, she is way smarter than me. So I simplified the UI my adding a toolbar and menus. Most of the functions will not be used all that often so It is better not to confuse a new user. I also think I can format big drive Fat32. Still testing.
Making Progress! ![]()
"Democracy Dies in Darkness" Last edited by Fraxum; 05-10-2016 at 03:01 PM. |
