Old 02-15-2016, 05:40 PM   #15
fastball
Drives: 2017 Camaro 2SS 6MT
You deserve a break today!
fastball is offline   Reply With Quote
Old 02-17-2016, 04:17 PM   #16
CamaroMX
CamaroMX's Avatar
Drives: Camaro 2016 RS
Exclamation Same here
I had exactlly the same problem, only difference i was not on curvy roads. She was parked and the problems came, like when the ABS comes on, a little vibration on the foot pedal and a noise in the back. It took 2 start ups for the problem to go away. Is this something we should be worried about?
CamaroMX is offline   Reply With Quote
Old 03-21-2016, 11:25 AM   #17
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
My son just had this happen to him. Any other news? I started the car and had no issues. Hate to take it to the dealer and not have the problem show itself.
Old 03-21-2016, 11:56 AM   #18
Tushar
Tushar's Avatar
Drives: 2016 2SS
its was very weird....it went away when I restarted my car.
Did not happen again even though i went on twisty roads fun rides recently....
Dream Big and Work Hard....cos you never know when your dreams may come true!!
2SS Garnet Red
NPP
Automatic
Tushar is offline   Reply With Quote
Old 03-21-2016, 11:59 AM   #19
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Check for leaks by looking at the Reservoirs level, it could be you are overheating the fluid on your twisty roads and causing that message could try bleeding with some higher temp fluid if not id bring it in.
thescreensavers is offline   Reply With Quote
Old 03-21-2016, 12:20 PM   #20
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
Now we have Break problems.
Marty McFlew is offline   Reply With Quote
Old 03-21-2016, 12:21 PM   #21
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Low voltage can trigger this. Take the batt and have it load tested.
Old 04-19-2016, 05:35 AM   #22
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
This just happened to me, scary feeling of brakes being that soft at high speeds.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 04-19-2016, 06:11 PM   #23
bybcous
bybcous's Avatar
They are replacing master cylinder tommorow morning.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 09-07-2018, 04:45 AM   #24
Rinker
Drives: 17' SS 1LE
did this fix your issue? This dash error message pops up for me under heavy braking or apexing turns hard.
Rinker is offline   Reply With Quote
Old 07-06-2020, 11:42 AM   #25
CowmaroV8
CowmaroV8's Avatar
Drives: 2016 Chevrolet Camaro 2SS
I just experienced this issue and thanks to checking in the forums here had it taken care of with a service bulletin. I understand this is an old forum, but with low mileage cars still out there, this issue is still very real in 2020 and I wanted to help anyone I could.
My brake assist warning came on and I lost about half my braking pressure and it felt that ABS was on 100% of the time. This is mentioned in the owners manual as normal behavior when the service message occurs.
I turned the car on the next day and the issue was gone but took it for service anyway. They told me there was a service bulletin and they will simply run a diagnostic and if no issues are found other than the TSB then that's all they will charge. It happened 8 hours prior the night before the computer had all the error codes stored so they were able to pull them up without any active CEL or Error Codes.
Should be a recall and not a TSB but just needed to share this as these forums are the reason I knew of the fix ahead of time. Maybe a diagnostic fee is worth the piece of mind to get the update needed rather than waiting for the brakes to fail in traffic as mine did.
"Internal software fault in EBCM. Reprogram EBCM per BULL#17-NA-048"
CowmaroV8 is offline   Reply With Quote
Old 07-07-2020, 09:24 AM   #26
BlueinTN
Drives: gas powered
https://www.camaro6.com/forums/showthread.php?t=576896
id post it on this thread as well.
2018 ZL1 ZLE
Oldblueaccord <<< MY YOUTUBE PAGE!
BlueinTN is offline   Reply With Quote
Old 04-20-2021, 05:59 AM   #27
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Originally Posted by Tushar View Post
So today morning after driving through some winding roads the service break assist warning popped up...
The break pedal feels jittery when pressed.
Taking for service tomorrow
Any ideas what may be wrong??
I had the light coming on then had a total assist failure. Took it to the dealership and they replaced the booster. Same thing happened again. Light came on a few times and while driving I lost all boosted braking. I spoke with the service department and they said the booster had hydro locked with oil. They have no idea on why. Leaving the dealership the light came back on. Still don’t know why this is happening or when I will loose the brakes again.
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
F419sr1 is offline   Reply With Quote
