Old 03-18-2016, 09:31 PM   #15
usmcfiredog
Drives: 2016 Black 2SS
So I finally got the correct mirror tap. Noticed one issue though that I finally figured out. To test the mirror tap car has to be running you can't check your work with just the accessory power on. This is nice it just threw me for a loop and a little aggravation.
Camaro 2SS
Black/Jet Black
A8, NPP, MRC, NAV
Low Gloss Black 5 Spoke
usmcfiredog is offline   Reply With Quote
Old 03-20-2016, 07:38 AM   #16
tejesh83
Yup, I wasted a lot of time figuring that out the hard way too during my install =)
What mirror tap did you use?
2016 2SS - Summit White - MT - NPP - MRC - NAV
tejesh83 is offline   Reply With Quote
Old 03-23-2016, 01:01 PM   #17
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
Drives: Red Rock Metallic ZL1
which mirror tap did you get and where?
Chad's ZL1 is offline   Reply With Quote
Old 03-23-2016, 06:37 PM   #18
usmcfiredog
I used the MT2015. I bought it from amazon here is the link
http://www.amazon.com/MirrorTap®-Rad...ilpage_o08_s00
Camaro 2SS
Black/Jet Black
A8, NPP, MRC, NAV
Old 03-23-2016, 06:38 PM   #19
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
thanks
Old 03-23-2016, 06:40 PM   #20
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
do you have the mirror like the zl1. I have the 2014
Old 03-23-2016, 06:45 PM   #21
usmcfiredog
The mirror on the 2016 camaro is the same as the c7 vet so I don't know what the 2014 Camaro has sorry. blendmount.com may be able to help you out more. also that mirror tap is for the 2016 because of where you hard wire it
Camaro 2SS
Black/Jet Black
A8, NPP, MRC, NAV
Old 03-26-2016, 04:11 PM   #22
p2architect
Drives: 1963 Pontiac Lemans
A few tricks
A technique to remove the dome light console. The console has three main clips that hold it in place, two on the side and one in the back. Back is referenced to back of car. Take two pieces of hard plastic. I used some cake icing kitchen tools. These plastic pieces will protect finishes. Wedge them in one of the sides of the console. About one inch back from the back of the console. Then slide a screwdriver in between the two pieces of hard plastic. Hold the two plastic wedges in place because you do not want them to slip in the next step or you may leave some scratches. Twist the screwdriver. This twist action will pop the side out. Do the other side use same procedure. It will pop out. Now the two side connectors are loose.
Next move to the back of the console. For reference again, back is the back of car. Slip the wedges in the center of the console, slide the screwdriver between the two pieces of plastic and twist screwdriver. Pop. Now the console is free. There are two hinges on the front. Just drops down.
No need to remove all of the electrical connectors. Just two. Remove the driver side dome light connector. Then remove the front clip in the center.
Removal of one dome light connector will allow the dome light console to swing out of way to make necessary connections.
As stated and shown. Put a cloth on the rear view mirror to protect finishes.
p2architect is offline   Reply With Quote
Old 03-26-2016, 04:32 PM   #23
stella16
1959 Chevy Apache 4X4
stella16's Avatar
Drives: 2017 ZL1
I just finished my install. It is going to take some getting use to. It is an easy install though. Thanks to everyone who contributed to the how to...:-)
I also have the harness with the mute button. If I don't like reaching up to the unit, I might have my local stereo shop cut the console and install it right in front of the accessory outlet. He is very talented. He could make it look factory. It would be an easy push to quiet the thing down
I live on the border of 3 towns/cities. In two of them, the cops have their radars on all of the time. The detector is almost always screaming
stella16 is offline   Reply With Quote
Old 04-06-2016, 08:36 AM   #24
Juttman88
Drives: 2016 Corvette Z51 (2LT)
I'm assuming it doesn't but just wanted to confirm, does hardwiring a radar detector void your warranty? Thanks guys!
Juttman
Juttman88 is offline   Reply With Quote
Old 04-07-2016, 06:02 PM   #25
usmcfiredog
Which warranty? It may depend how you tap into the wires.
Camaro 2SS
Black/Jet Black
A8, NPP, MRC, NAV
Old 05-03-2016, 11:39 AM   #26
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Originally Posted by tejesh83 View Post
...[*]On the back of the plug that feeds the airbag light, tap the Purple/White (+12V) and Black (-GND) wires....
Maybe a dumb question, but given that the airbag light is only illuminated when you have no passenger, does the purple/wh still have power if someone is seated in the passenger seat?
Emoto is offline   Reply With Quote
Old 05-04-2016, 01:52 AM   #27
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
It stays on for me.
I want to note that my installer initially tried the switched power for the rear view mirror. For some crazy-ass reason it only worked when I turned accessories on first then cranked the starter. My installer checked the voltage and it seems that if you just step in the car and start it, the voltage only shows 10v but if you start the accessories first then start the actual motor it shows 12v.
He switched to the airbag one as the OP instructed and it works fine now.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 05-04-2016, 08:20 AM   #28
Emoto
Sure, why not?
Emoto's Avatar
Good to know. Thanks, bpang1234!
