Old 02-06-2016, 10:16 AM   #15
6spdhyperblue
Drives: 2SS 1LE
you blipped it and didn't really heat up the main and rod bearings. if youre a believer in breaking in the engine it wasn't the worst thing to happen.
as far as over rev, how fast were you going? then we can figure out if you were in the RPM range for damage.
Old 02-06-2016, 10:36 AM   #16
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
Originally Posted by Eric SS View Post
I'm shocked it took his long for someone to say this. Rev limiters do nothing to protect against over revving on accidental downshifts.
^^^THIS... Break in is not just for your motor, it also includes the transmission and rear differential. If your engine is running ok, no problem. I have seen a few threads of people doing this and it bent some valves.
Old 02-06-2016, 10:48 AM   #17
SPCBA
Drives: pleather and Chiclets
As long as you didn't mechanically rev (as explained above its not saved by the computer) it way beyond capacity you are ok. How is t running any leaks and new noises?
SPCBA is offline   Reply With Quote
Old 02-06-2016, 10:55 AM   #18
garfin
Resident Disciple
garfin's Avatar
Drives: 2010 CTS-V 6MN '98 Camaro SS (Sold)
Originally Posted by 2000form View Post
Rev limiter only effects accelerating rpms, probably by fuel cutoff. When you have a mechanical over rev, like going into the wrong gear, it can be catastrophic. Like others said gm makes some good engines so there is a real good chance you're ok. I guess time will tell.
Exactly!!
I hate to admit it, but I managed to shift 3-2, at redline while in 3rd - on the dragstrip in my 4th Gen SS. Horrible experience! The force would have put me through the front windshield if I hadn't been wearing the shoulder belt! The result was smacked valves and a mess of bent pushrods.
From that day on, I started shifting from 3rd to 4th backhanded by rotating the palm of my hand 180 degrees so it's facing the passenger door instead of the driver door. You don't "grip" the shifter using this technique, but rather you"push" the shifter into 4th with the palm of your hand. There is a natural motion pushing away from gate for 2nd gear when you do it like is, thus avoiding the dreaded 3-2 misshift when trying to upshift into 4th. It's just as quick a shift to make this way and it's easy to use on road courses as well, anticipating an upshift from 3rd to 4th. Try it. It works.
Best regards,
Elie
2010 Cadillac CTS-V 6MN Thunder Gray
1998 Camaro SS # C079 SOLD
garfin is offline   Reply With Quote
Old 02-06-2016, 11:02 AM   #19
LikaRokBowTie
Drives: 221SS1LE
Yeah it's ruined I'll give you 2500$ for it
LikaRokBowTie is offline   Reply With Quote
Old 02-06-2016, 11:07 AM   #20
bballr4567
Drives: 2016 Camaro 1LT M6
Originally Posted by garfin View Post
Exactly!!
Best regards,
Elie
Yup. 100%. Ranger has some really good instruction videos that explain this exactly. It's all shifter technique.
bballr4567 is offline   Reply With Quote
Old 02-06-2016, 11:45 AM   #21
garfin
Resident Disciple
garfin's Avatar
Found this:
Good instruction/explanation of this - how to shift from 3rd to 4th at 2:20.
Also good tips for the 2-3 upshift...
Best regards,
Elie
Old 02-06-2016, 11:47 AM   #22
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
I can't believe some people still think that a Rev limiter will stop a mechanical over Rev. That's truly sad from any man who calls himself a "car guy". Especially one who drives a stick.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 02-06-2016, 12:28 PM   #23
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Exactly!!
Best regards,
Elie
I still do this out of habit on every 3-4 shift even when I'm not racing. It becomes 2nd nature after a while.
Eric SS is offline   Reply With Quote
Old 02-06-2016, 01:13 PM   #24
fastball
Drives: 2017 Camaro 2SS 6MT
Originally Posted by Drags1998 View Post
You couldn't hurt it if you tried!!!!! They have gotten so good at building engines and limiting them with Rev controls and fuel shutoffs that you WON'T hurt it. PERIOD!!!!! The guy in the Vid. lost a Tranny, Not a Motor!!!
Lol..... DEFINITELY not true.
The reason the transmission was invented was so a car could go faster than the engine can rev. A rev limiter can only shut fuel off. You jam the transmission into a lower gear than the engine can turn for the speed the car is moving the engine WILL over rev.
fastball is offline   Reply With Quote
Old 02-06-2016, 02:15 PM   #25
MikeyCamaro
Drives: 2015 Challenger SRT
LMAO. I'll give you $3000. Seriously though, you're probably OK up to redline or even a little over. It's when you zing it well past redline that you're in for trouble.
You know, I've often wondered in this day of rev matching, hill assist, and solenoid lockouts, why not put a lockout on each gate and simply lock out the ones that would result in an over-rev based on your current speed? Seems like that'd be an easy thing to do! I realize there could be times when you want to pre-shift into a gear while slowing so you'll be ready to release the clutch at the lower speed, but it could at least be an option.
Mike
MikeyCamaro is offline   Reply With Quote
Old 02-06-2016, 02:21 PM   #26
LikaRokBowTie
Drives: 221SS1LE
I concur,if it happened multiple times you'd be in trouble but should be okay with one or two occurrences at the most.So I guess 2500 won't get it
Old 02-06-2016, 02:54 PM   #27
Drags1998
Drives: 15 SilveradoLTZ,162SSVert BlazerRS
Fastball, I suppose your right!! What I should have said is: Except for 1 choosing the the wrong gear by mistake you could not hurt it!!!! I have NEVER {including 12years of drag racing w/manual trans} chosen the WRONG gear. Its hard on a forum to have everyone on the same wavelength!! I know that driving talent varies between people and I should have thought of that. So, I stand corrected!!!
Drags1998 is offline   Reply With Quote
Old 02-06-2016, 03:35 PM   #28
fastball
Mike
That's actually a really great idea. I'm surprised no one has come up with that.
