Old 03-08-2016, 10:09 PM   #15
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
Originally Posted by bybcous View Post
On a cold startup, i reversed out of my drive way and when i put the car in drive, my dlc said performance shift active, and the car started accelerating pretty hard. This stopped once i pushed my brakes. Just posting in case this turns out to be a software glitch down the line.
You mean your Toyota?
Marty McFlew is offline   Reply With Quote
Old 03-09-2016, 10:40 AM   #16
cwl011
I have found that you have to let the car get to normal idle rpms before you start moving. I have noticed that he 7K-9K rpms is the right spot. Plus it is good practice to start the car and let it idle for i little bit before moving so oil gets to the top of the engine. It takes about a minute to let it calm down. If you can't start your car and wait one minute before pulling out then
cwl011 is offline   Reply With Quote
Old 03-09-2016, 10:50 AM   #17
cwl011
Also we are talking about a car that has 455 lb-ft, a little bit of rpms goes a long way. When i am sitting in traffic on a level road, i will give it a little throttle to start moving but once moving i can let my foot off the throttle and my car will travel at 5 mph and not stall out.
Old 03-09-2016, 12:32 PM   #18
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
I thought only the COPO could do that!
Old 03-09-2016, 01:19 PM   #19
bballr4567
Drives: 2016 Camaro 1LT M6
The Camaro has a higher idle when you first start it than a lot of cars I've owned. I can only guess as to the reasons but one has to do with the DI and not having the fuel coat the cold valves so they upped the RPMs. The other guess has to be with getting the cats up to temp faster which helps with emissions.
Just wait the five seconds before the moving.
bballr4567 is offline   Reply With Quote
Old 03-09-2016, 02:01 PM   #20
Netslave
GM paint evaluation dept
Netslave's Avatar
Drives: Too many to list
Cold start/high rpm is understood. Our car was holding 1500-2k rpms without pushing the accelerator. Has happened multiple times with the car being ran for as little as 5 minutes or as long as an hour. We told it was not replicated, like the rear end noise, like the npp noise, options in the audio/system menu disappearing and reappearing etc.
Co-owner of Tony the Tiger
- A GM factory custom orange and mosaic black striped 2016 SS 2SS
- U̶n̶o̶f̶f̶i̶c̶i̶a̶l̶l̶y̶ Officially the worst Mosaic Black paint on a 2016 Camaro SS 2SS
See him here -
https://drive.google.com/folderview?...3M&usp=sharing
Netslave is offline   Reply With Quote
