#15 | |
![]() Drives: 2016 2SS Join Date: Sep 2015
It might not help, but it is an easy try... It has helped sometimes when my iphone is doing silly things with the ford sync in the Escape I own.
My first: 1976 LT, My second: 1984 Sport, with lots of stuff in-between and since. The third: 2016 2SS, garnet red, manual, navigation, dual mode exhaust, magnetic ride, black 5 spoke rims....
The Journey 1100 - 09/28/15 : 2000 - 11/17/15 : 2500 - 11/18/15 : 3000 - 11/19/15 : 3000 - 11/21/15 - TPW 12/21/15 : 3100 - 12/08/15 : 3300 - 12/10/15 : 3400 - 12/11/15 : 3800 - 12/18/2015 VIN: 0135101 : 12/21/15 - 4300 : 12/30/15 - 4200 : 12/31/15 - 4300 : 1/1/16 - 4B00 : 1/4/2016 - 4200 : 1/12/2016 - 4B00 : 1/13/16 - 5000 : 1/14/16 - 6000 |
#16 |
![]() ![]() Drives: 1968 SS/RS, 2006 H2 2016 2SS White Join Date: Sep 2015
Off topic, just a little, I transferred all my iTunes music to a flash drive, works great and very easy to do. Just plug into sub and go
2016 2SS White fully loaded
#17 |
USB, damn auto correct
#18 |
![]() Drives: Nightfall Gray 2LT RS Join Date: Aug 2012
Did this fix it for you Zack? I had to do this with my phone because of a few glitches I was noticing after connecting to the Car Play and it fixed them. Also would check the USB cord as stated, I had mine disconnect a few times with an older cord I was using, I switched to a new cord and haven't had any issues since. Hope it's nothing major.
My Build Journal, Review, and Photos: Here |
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 2SS Camaro Hot Wheels Edition Join Date: Sep 2015
Zack46
2018 Camaro 2SS Orange Crush Hot Wheels Limited Edition Power Sunroof, 8 Speed Auto/Remote Start, NPP Exhaust Production Sequence Number 98 NEOCC Camaro Club Member Former Ride: 2016 Camaro 2LT RS V6 Hyper Blue Metallic |
#21 | |
![]() Drives: 2017 2.0 camaro Join Date: Mar 2017
My carplay isnt working either
My apple carplay stopped working about 3 months after i got the car. So far what i have done is a reset within the radio settings and a hard reset my iphone. That didn't solve the problem so i took the car to the dealer and after 3 days they diagnose it(with GM's help) the radio module needing replacement. It was replaced today and the dealer just called to tell me that carplay still doesnt work. So they are calling GM because they can't solve the issue alone. Were you able to solve this issue? Did you go to the dealer and if so what did they do to fix it? I know it's not my ports cuz the phone still gets a charge and i know it's not the cable cuz i used 2 different iphone cables. The ones that come with the phone when purchased. I tried it with my iphone 6s+ and an iphone 6. |
#22 |
![]() Drives: 2016 Camaro SS Convertible 2SS Join Date: Dec 2016
I had the same issue just happen today on my 2016 SS. It's not a daily driver so it's not being over used or abused. Wife used her phone on it roughly 10 days ago. Tried mine today and nothing, won't even charge. Tried it on her iphone and nothing again. Then proceeded to try her iPhone cord on both phones...again not even a charge. Wondering if the USB ports lost power or tripped a fuse or something. Only got about 1100 miles on it thus far. Bluetooth works fine to play music and use for the phone. I use the carplay for the maps from my phone primarily since the navigation leaves something to be desired in these Chevrolets. Still love them but their nav screen sucks.
#23 |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
Lots of us have had problems with the actual USB connection. Go look it up in a search.
If your cords are working in terms of using them elsewhere (to charge the phone or sync it to a PC) then it could be the USB connection broke in your car. When you plug it in, is it starting to charge? I know it won't connect to Carplay but I'd like to know if electricity is moving through it. 1. Test the cords you are using by using them for regular charging OR syncing to PC. 2. Check if the cords are at least pushing power through to the phone by seeing if it will charge in the car. If the USB Connection is broken, GM will need to replace it for you. Hopefully faster than it took to fix mine.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
#24 | |
#25 |
I highly recommend this thread for anyone who's phone is NOT being recognized by the USB ports. That is the phone isn't even being charged. I did the battery reset and everything was normal two mins later.
http://www.camaro6.com/forums/showthread.php?t=435358
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
#26 |
This problem recurred two weeks ago. I need to fix it yet, but there's gotta be a permanent fix for this from GM.
Formerly owner of:
#27 | |
![]() Drives: 2016 2.0 LT1 RS Join Date: Feb 2017
Open your truck, on the right side you will see a plastic script, (one of those plastic Xmas tree shaped fasteners. Remove it, pull the liner away to expose the battery. there is a plastic cover to remove it, squeeze both sides, and it should slide off. next you will need a 13 MM wrench or socket and ratchet, remove the RED lead. be careful . Then touch the removed battery lead against the NEGATIVE terminal of the battery. Then reinstall everything as you took it apart. This should reset your apple car play. |
#28 |
Summit White 2SS
Drives: 2017 Summit White 2SS, 2018 Tahoe Join Date: Nov 2016
There is a fix. Bulletin 17-NA-019. Your dealership can update the radio software.
____________________ 2017 Summit White 2SS |
