#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
So throttle progression is stuck to the mode you are in, and can't be independently controlled? Kind of a bummer...but really not a big deal to me either.
TR6 whom has his Camaro now, says between tour mode, and track mode, the throttle progression is a very noticeable difference.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#16 |
![]() ![]() ![]() Drives: 08 Accord V6/M6 / 04 Canyon Z71 Join Date: Aug 2008
Well throttle and shifting are technically locked to the main driver mode selection. If you have a manual, then its just the throttle progression.
You should be able to choose the overall track mode to get that throttle progression, then change the suspension, steering, and exhaust to your liking. |
#17 | |
![]() ![]() Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
It's just curious to me that GM has 4 adjustable parameters for the Drive Modes, but one not customizable like the other three... I could see GM wanting to lock throttle to being less sensitive in Weather Mode, but why restrict its customization across the board?
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 |
#18 | |
Have you confirmed that you can't change settings on the fly? If you look at my video it only takes four presses to change an individual driving mode setting. They could probably change the interface to make it quicker, but once again, is the extra cost worth it for something that won't be adjusted very often. |
