Old 11-30-2015, 08:48 PM   #15
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
Originally Posted by SUMMIT WHITE SS View Post
Your GTA was able to do that due to numerically higher gears in the rear and less weight to get moving out of the hole. Plus, the TPI's actually had decent low end torque. The ZL1 has more torque, numerically higher gears, and a different transmission and the Vettes (assuming you mean C7's) are lighter...
I spend tons of time at the drag strip (I probably have over 500 passes) with various cars, and I still say that the chances of a stock, A8 SS hitting something better then a 1.8 60' are near zero. Between the numerically low gears in the rear, soft converter, and it's weight. Heck, even the very, very few "hero runs" that some on this forum like to call them, for the A8 C7's are in the 1.7 60' range (and it's only like two cars). The vast majority are in the 1.8/1.9 60' range, which is where you will see the A8 SS in my opinion.
Well since you spend so much time at the track I'm sure you know that going from high 1.9's to low 1.8's is huge on the et. And even though the zl1 had more low end it also had alot more weight. The new camaro also has an advantage with its more aggressive gearing in the 8speed auto. The mph is a clear indication of the HP/weight of the zl1 vs 6th gen SS. On paper the zl1 should handle it with ease but that may not be that case in the real world.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 11-30-2015, 09:52 PM   #16
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
The Hot Rod pass that was a 12.28 or something like that, if I recall was a 1.86 60' on the slip I saw. That was on a prepped drag strip on a cool day. If I recall the driver was some pro drag racer. My old self can't remember who though. That is going to be about the best 60' you will see all stock on an A8, unless you get mine shaft DA. 1.86, for a bone stock car on street tires is pretty good. Should be easy to hit near that with the A8, will take skill to do it with the M6. But that is what makes it fun...
Old 12-01-2015, 09:26 AM   #17
NASTY99Z28
Agreed. I'm sure with some cold weather and neg da we will see some high 11.9's but it won't be the norm. Mid to low 12's should be easy for the auto guys. The manual guys are always a toss up because most people will have a hard time launching hard enough or not blowing the tires off one the 1>2 shift. What I really wanna see is some slicks and driver not scared to get after it!!!! I wish the camaro guys were as crazy as the mustang guys.
Old 12-01-2015, 11:53 AM   #18
ULTRAZLS1
ULTRAZLS1's Avatar
The scat has gone as fast as 11.89 with only DR supposedly. Also seen an 11.69 with hellcat intake only and DR. 60 ft was 1.6-7. Those are the best times currently. I think the best totally stock is 12.1.
Camaro should be able to do a bit better all around.
Old 12-01-2015, 12:00 PM   #19
SpeedIsLife
Drives: Current Camaro-less
I agree.
The Scat Packs are *slightly* more aggressively geared, both in the transmission and in the final drive ratio and make a bit more HP and TQ, as well as having a better exhaust system stock. However it's also easily 425lbs more, which should shift the advantage back to the Camaro.
Old 12-06-2015, 09:58 AM   #20
Merc
In The Circle
Merc's Avatar
I see we now have a couple of time slips posted in another thread, so I assume those people will post to this thread soon. It's time to limit this thread to time slip posting and move the chat off. Every ones cooperation will be appreciated in the future.
Please take the time to read how to post your times slips for inclusion.
Old 12-07-2015, 06:34 PM   #21
Merc
In The Circle
Merc's Avatar
Old 12-07-2015, 06:55 PM   #22
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Get that car from the other thread on the list...12.0 stock, 11.9 tire.
Old 12-07-2015, 07:00 PM   #23
Merc
In The Circle
Merc's Avatar
He has yet to post the slip.
Old 12-07-2015, 08:08 PM   #24
trz174
trz174's Avatar
Drives: .
2016 2SS Camaro, A8, NPP, 6 Piston Brembo Front
Tires used on the pass: Goodyear stock, Rear 22 PSI, Front 35 PSI
Performance Mods (if any): None
Category submitted for: Bone Stock on Stock Tires
R/T: .046
60': 1.779
330': 5.099
660': 7.800
660’ mph: 91.52
1000': 10.112
1320': 12.070
1320’ mph: 116.25
Name of the track: South Georgia Motor Sports Park, Adel GA
Date of pass: December 5, 2015, 11:14AM
Weather conditions: (include Density Altitude, Optional)
Other: SGMP Scale Weight - 3,715 lbs; 1/4 tank 93 octane
trz174 is offline   Reply With Quote
Old 12-07-2015, 08:15 PM   #25
trz174
trz174's Avatar
Drives: .
Tires used on the pass: MT ET Streets Rear 18 PSI, Goodyear stock Front 35 PSI
Category submitted for: Bone Stock on Drag Radials
R/T: .233
60': 1.731
330': 5.013
660': 7.683
660’ mph: 92.36
1000': 9.972
1320': 11.913
1320’ mph: 115.87
Date of pass: December 5, 2015, 11:45AM
Old 12-07-2015, 08:25 PM   #26
trz174
trz174's Avatar
Drives: .
For what it's worth, we hot lapped and here is the second run on Drag Radials that was done 5 mins after we ran the 11.913 run.
Old 12-08-2015, 08:44 AM   #27
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
I see it's there now, but while the car did have drag radials, on the 11.9 run it did not have skinnies on it...but it says it does on the chart?
Old 12-08-2015, 03:15 PM   #28
Merc
In The Circle
Merc's Avatar
It was pictured with skinnies on in a another post. I can change that.
