Old 10-13-2015, 10:56 AM   #15
Trans damm
Drives: Trans am
Grabbed this off of corvette forum. No idea on accuracy. Claiming an LT7 is in the works, FPC NA
Trans damm is offline   Reply With Quote
Old 10-13-2015, 11:22 AM   #16
Bhobbs
Bhobbs's Avatar
Flat plane crank doesn't make sense in an OHV engine. The valve train won't be stable enough to take advantage of the rev capability.
Edit: This could be a Cadillac specific engine and move to a DOHC engine.
GM has already said a DTC system that could handle the torque of the LT4 would be too heavy. They already have the 8 speed auto and have been working on 9 and 10 speeds with Ford.
Old 10-13-2015, 11:42 AM   #17
SpeedIsLife
Drives: Current Camaro-less
I find it suspicious that Ford grabbed international auto headlines with the 5.2 FPC and now someone is claiming that GM is also.
Seems like a desperate "me too! me too!"
Old 10-13-2015, 11:51 AM   #18
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Originally Posted by Raven87 View Post
Any thoughts as to whether GM would remove the blower from the LT4 and leaved the forged internals to have a Naturally aspirated track-capable engine for the Z/28?
I think it would be an awesome motor, especially if they kept the HP north of 525-ish. It would be a good replacement for the fail-prone LS7 as a high HP N/A option.
Interesting to think about...
it's not that simple. they would have change the compression ratio, camshaft profiles, etc.
it would be a new motor. they would probably stick with hypereutectic pistons in a n/a motor as well as they have a more optimum thermal expansion coefficient and you don't need a forged piston in that power range at all.
you pull the blower off and lt4 and you probably just have a 400-425hp motor.
my ls7 lasted perfectly for 5 years but I was stock. I did inspect the valve train geometry based on the paranoia around the platform though.
2016 2SS
2020 super duty on 37's
hognutz is offline   Reply With Quote
Old 10-13-2015, 12:01 PM   #19
Raven87
C'mon- really?
Raven87's Avatar
Drives: Looking for a ZL1
I agree, it would be much more complex than just 'removing a blower'. But I was referencing the forged internals in particular for strength and reliability for an N/A motor.
Thanks.
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD
Raven87 is offline   Reply With Quote
Old 10-16-2015, 10:39 PM   #20
396ssrat
Drives: 66 Chevelle SS
For the money the Gen 5 Camaro Z28 is underpowered. That car is in dire need of 625 hp.
