#15 |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
To answer your #9 question.. It is worth it on my opinion. A couple reasons:
1) its still much cheaper than a borla/corsa catback and we KNOW you will be getting that FAST! So save some money. 2) you get the butterfly which during a road trip you can cut the noise levels way down by switching the mode you are driving in. 3) while catback is a joke to install, car comes with it installed thus less time to do something and you can tackle installing something else :P (saves time, time is money my friend!) 4) Sound is fantastic for stock, it'll keep you satisfied till companies release their own products which will take a month or two I would assume, at least. 5) quad tip, nuff said. |
#16 |
![]() Drives: Trans am Join Date: Jan 2015
Yes, get it if you can swing it. Go down to the Chevy dealer and check out a vette with it.
#17 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#18 | ||
You can actually hear the exhaust change as he toggles the setting. Also the Scat Pack cars have their valves open in in sport mode, which can be made the default mode for the car. So sound regulations must be peculiar.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 2SS Camaro Hot Wheels Edition Join Date: Sep 2015
Is the stock exhaust noisy on the highway inside the cabin? Can you hear it when your driving? Since, you can't change the noise level.
Zack46
2018 Camaro 2SS Orange Crush Hot Wheels Limited Edition Power Sunroof, 8 Speed Auto/Remote Start, NPP Exhaust Production Sequence Number 98 NEOCC Camaro Club Member Former Ride: 2016 Camaro 2LT RS V6 Hyper Blue Metallic |
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 1969 Corvair, 2018 Camaro T4 RS Join Date: Mar 2009
Unless one is planning to change the exhaust to aftermarket, then NPP is definitely worth it.
Laborsmith |
#21 |
Dodges all the cones
Drives: Soon Join Date: Sep 2015
Mine will have the NPP as I do leave sometimes as early as 430 to catch flights at 630ish.
--kC |
#22 |
![]() Drives: 2001 Camaro SS Join Date: Nov 2009
I would opt for this without a second thought. That factory 2016 x-pipe exhaust is quite good and sounds good open or closed. A friend of mine has a 05 C6 Vette making 790 hp to the rear wheels and is running an OEM dual mode exhaust from a newer C6 Z06. The controller for switching the exhaust was run through the homelink buttons on the sun visor. With the exhaust closed you'd never know the car is what it is, its so quiet and tame and barely audible in the car at highway cruise speeds. Open the exhaust and its a different story
2001 Camaro SS- M6 cone killer
#23 | |
Sent from my SAMSUNG-SM-N900A using Tapatalk
#24 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
#25 |
![]() Drives: Impala Join Date: May 2015
You can go in through the driver display and set any exhaust mode for any driving mode. Actually through the display you can set all variables for each driving mode. You can tweak things to how you want them. Been discussed on here before. Don't have time to search for the thread.
#26 |
For V6 Camaro owners does it make any sense to get the NPP exhaust OR is the NPP just meant for the V8 engine?
Zack46
#27 |
I used a No Weeds electronically controlled diverter on my 2010 LT (NPP not available for Camaro back then) and I was quite happy with it.
Therefore, yes, I believe NPP would be worth it on both the V6 and the V8 Camaro. Laborsmith |
#28 |
![]() Drives: 2016 Chevrolet Camaro SS Join Date: Sep 2015
There's a button to control the sound of the exhaust? can some one post picture
2016 Camaro 2SS - Bright Yellow
Ordered on 9/22 Built on 11/10 Delivered on 12/15/15 |
