09-23-2015, 02:10 PM | #15 | |
Drives: 2011 Camaro 2ss Join Date: May 2013
09-23-2015, 02:22 PM | #16 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
09-23-2015, 02:55 PM | #17 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Some very good points here.
I know when I first tracked my ZL1 I noticed a big different in weight compared to the LFX V6 I used to track. I would also agree that a base ZL1 vs a stock 1LE on the track is closer than most people realize. It's not until you start modding both cars that you see the major differences. The ZL1 can just take high HP mods and keep on ticking without any major issue. The 1LE is a great car but you can only bolt so much on before things start to break. I also agree that if there is a new ZL1 or Z/28 that it will be around 70-75k to pick one up. The price bump from the old 2SS to the 6th Gen 2SS proves that.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
09-23-2015, 03:01 PM | #18 |
Drives: 99z28 with bolt-ons and a mwc fab 9 Join Date: Jul 2012
Big brakes,rims, tires, better aero, stronger rearends,halfshafts,blower and better transmission. Plenty of room and parts to add. Just bring money.
I like my woman like my milk shakes, THICK!!!!
09-23-2015, 04:20 PM | #19 | |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
(Taken from the ZLE-registry website - 1LE Specific Part Numbers: Strut Tower Brace (LT, SS, 1LE) - 22756880 Wheel Hubs (ZL1, 1LE) (4) - 25954415 Front Coil Spring (SS, 1LE) (2) - 92245257 Front Strut (1LE) (passenger side) - 22812984 Front Strut (1LE) (driver side) - 22812985 Front Sway Bar (1LE) - 22812946 Front Sway End Link (SS, ZL1, 1LE) (passenger side) - 22842515 Front Sway End Link (SS, ZL1, 1LE) (driver side) - 22842516 Rear Shock Mount (ZL1, 1LE) (passenger side upper) - 22836734 Rear Shock Mount (ZL1, 1LE) (driver side upper) - 22836727 Rear Coil Spring (SS, 1LE) (2) - 92195466 Rear Shocks (1LE) (2) - 22812987 Rear Sway Bar (ZL1, 1LE) - 22786260 Rear Sway Bar Endlink (SS, ZL1, 1LE) (2) - 22761221 Rear Lower Control Arm (SS, ZL1, 1LE) (2) - 20942237 (Needed for 2010-2011 car conversion) Rear Toe Link (ZL1, 1LE) (2) - 22845487 3.91 Gears only ( 1LE ) - 22813040 Front Splitter kit ( 1LE ) - 22950575 Wheels 20x10 Black ( ZL1-1LE ) - 22798741 Wheels 20x11 Black ( ZL1-1LE ) - 22798743
09-23-2015, 05:15 PM | #20 | |
Drives: 2018 ZL1 6M, Silverado High Country Join Date: Oct 2008
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof 2019 Silverado High Country, Daily Driver |
09-23-2015, 05:26 PM | #21 |
Your right there are 3 parts, that are taken from the ZL1 only.
Rear Toe Link (ZL1, 1LE) (2) - 22845487 Rear Sway Bar (ZL1, 1LE) - 22786260 Wheel Hubs (ZL1, 1LE) (4) - 25954415 And one of the 2 sets of rims that came on the ZL1, but the diff is not the same, the axles are not, the brakes are not, clutch is not, the trans is not, Do they share most of the same sheet metal, yes they do,so does this mean all SS have ZL1 parts on them? Last edited by 2SSRS@Gen5diy; 09-23-2015 at 06:29 PM. |
09-23-2015, 05:41 PM | #22 | |
09-23-2015, 06:18 PM | #23 |
Some Zl1 came with leather steering wheel's, shifter is the same as any of the SS only the microfiber is new, don't think the 1LE came with the high flow pump, the Z/28 did but not the 1LE.
09-23-2015, 06:22 PM | #24 |
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
WOW. I mean if you are going to argue be civilized and spell check gentleman. LOL It is going to be ok in reality none of this will matter when the zl1 or 1le comes out. It could be completely different. I do want to thank both of you for the information given. It has been a good read so far!
09-23-2015, 06:36 PM | #25 |
Drives: truck Join Date: Aug 2015
Just curious if any of you think any existing corvette parts beyond the LT4 might make it into the ZL1? Or if not the same part exactly, just the technology? Or maybe I should be looking at the new CTS-V for clues?
Thanks, I'll take my answer off the air. |
09-24-2015, 01:31 PM | #26 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
I don't think the LT4 will be used at all. More likely we'll get a new motor that produces 600/600 and can be mass produced as a benchmark for future vehicles. I wouldn't be surprised if it has turbines instead of screws, LF inspired head design and weigh less than the LT4. Plus not as expensive as the LT4.
And both of the recent cars still running laps are two trims of the same model. GM learned their lesson on the Z28. People want a complete interior and don't want to spend 20k over the next highest model to get a race car. Instead, they will take the approach which seems to be looking good for Chevy (Z06/Z07) and Ford (GT350/GT350R). Put the bells in A and spend another 6-8k to get the whistles as well. It will fit all the desires for 1LE/ZL1/Z28 buyers. |
09-24-2015, 02:28 PM | #27 | |
GM never expected the Z/28 to be a volume seller. They knew they were going after a niche market.
09-24-2015, 02:48 PM | #28 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
I would opt for and spend the money for a Copo if they would put a VIN on it to be street legal. However, i do plan to get a ZL1 50th ed if offered and keep my current as a DD.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
