Old 05-25-2015, 10:17 AM   #15
toehead93
Drives: 2014 2SS/1LE
I was disappointed but after seeing the ratios it just helps with overdrive mpg on highway. I was hoping the M7 would get special gearing for a future 1LE option that utilized 6 gears better for the track and kept 7th for OD. Oh well, not the end of the world the best feature is the rev matching feature.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 05-25-2015, 11:19 AM   #16
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Yep. The engineer I talked to at the unveal said it wont fit.
Ive got buddys with stingrays that say they dont even use 7th.
I love both 6060 cars Ive owned. Powershifts effortlessly.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 05-25-2015, 11:51 AM   #17
Capricio
Drives: 2000 WS6
Seems unlikely the General would use a transmission in Corvettes only. That's a pretty low volume overall for something they developed at considerable expense. I almost have to believe we'll see that 7 speed somewhere else, eventually.
Capricio is offline   Reply With Quote
Old 05-25-2015, 12:07 PM   #18
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
Only measurements I could find is the six speed for the Camaro is 81mm Center Point Distance and the seven speed for the Corvette is 85mm Center Point Distance.
I have no real idea what Center Point Distance refers to.
Laborsmith
laborsmith is offline   Reply With Quote
Old 05-25-2015, 01:05 PM   #19
toehead93
It's the distance from the center point.
2010 2SS A6 - sold.
Old 05-25-2015, 01:08 PM   #20
toehead93
Sorry I couldn't even find anything on Google. I suspect it is the radius or diameter from center
2010 2SS A6 - sold.
Old 05-25-2015, 01:14 PM   #21
laborsmith
Well, until Number 3 weighs in, we do know one is bigger than the other in some way.
Laborsmith
Old 05-25-2015, 06:37 PM   #22
obzidian
obzidian's Avatar
Drives: 98 camaro turbo
A 6speed with a zr1 gearset is where its at! The 6th gear us actually functional!
obzidian is offline   Reply With Quote
Old 05-25-2015, 09:55 PM   #23
BahamaTodd
BahamaTodd's Avatar
Drives: 08 Accord V6/M6 / 04 Canyon Z71
I knew it was only an extra OD. Especially with no AFM on the manual, the M7 would have been nice to have.
BahamaTodd is offline   Reply With Quote
Old 05-26-2015, 08:05 AM   #24
xgnxs
xgnxs's Avatar
Drives: 2005 Cobalt Base - 5 speed
Originally Posted by VADER SS L99 View Post
I keep reading that people are disappointed that the 6th gen is not getting the TR-6070 7 speed in favor of the TR-6060 6 speed. Why is this? Did you think it had better gearing for performance? Did you just want 3 overdrive gears? Did you think it was a stronger trans? Does it shift better? Did you want it for better mpg?
I bet most of you thought that the 7 speed had more forward gears and better ratios for performance. I'm here to tell you that the 7 speed has 4 forward gears just like the 6 speed. The 7 speed just has a extra overdrive.
Look at the 7 speed ratios
1st-2.97
2nd-2.07
3rd-1.43
4th-1.00
5th-.71
6th-.57
7th-.48
Now look at the 6 speed ratios
1st-3.01
2nd-2.07
3rd-1.43
4th-1.00
5th-.84
6th-.57
As you can see the gearing is almost identical other than the fact that the 6th speed has a little stronger 1st gear and no 7th gear. Torque capacity of the 7speed is only 20ftlbs better. Considering the TR-6060 has gone in such cars as the ZL1 and GT-500 I think it will be plenty strong for a 6th gen SS. As far as shifting, well I wouldn't know. I guess you would have to drive a C7 and then a ATS-V back to back. The only real thing I see it helping is mpg and that's a maybe.
Those aren't the gear ratios that the 6th gen SS will get. From http://www.*********media.com/produc...aro-specs.html, 1st - 2.66, 2nd - 1.78, 3rd - 1.30, 4th - 1.00, 5th - 0.74, 6th - 0.50
xgnxs is offline   Reply With Quote
Old 05-26-2015, 01:16 PM   #25
396ssrat
Drives: 66 Chevelle SS
8 spd Automatic is where it's at.
Old 05-26-2015, 02:10 PM   #26
fastball
Drives: 2017 Camaro 2SS 6MT
You mean it won't get the 4+3 overdrive? hehe
fastball is offline   Reply With Quote
Old 05-26-2015, 04:17 PM   #27
ferrarimanf355
ferrarimanf355's Avatar
Drives: 2011 Fiat 500 Sport... shut up...
Send a message via AIM to ferrarimanf355 Send a message via MSN to ferrarimanf355 Send a message via Yahoo to ferrarimanf355 Send a message via Skype™ to ferrarimanf355
Truth be told, I can't drive stick, so I'm happy that the Camaro is getting an eight-speed auto. I think the 8AT worked wonders in the 2015 Challenger, so seeing it in a car that's possibly 400-500 pounds lighter should do wonders with the acceleration. And isn't acceleration why people love muscle cars- or sports cars in general- in the first place?
I'm guessing the reason why they didn't put the 7MT in is because of packaging issues, anyone know the reason why?
ferrarimanf355 is offline   Reply With Quote
Old 05-26-2015, 04:37 PM   #28
Jeffro19
Jeffro19's Avatar
I have Heard that the 7 spd wouldn't fit
