#15 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Really Slow Join Date: Apr 2010
wasn't sure what that meant. How do I know if it detects 2 different wifi signals? when I open up the wifi, it shows maybe 10-15 wifi options from people around me. I just selected the one that was on the bottom of the modem. And there was only that one that I saw.
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 45th Anniversary 2SS LS3 Join Date: Feb 2012
You can also help out your wireless network by choosing a channel that is as far away from surrounding networks as possible.
For example if your neighbor is using channel 10, you should try using a low channel.
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 IOM Camaro Join Date: Jul 2010
I think netgear uses "Netgear 2.4 G" for the 2.4 Ghz band and "Netgear Dualband N" for the 5Ghz band. I can't remember exactly what names netgear uses for their wifi since I changed mine a while back. Mine are "Firecracker" for the 2.4 and "Rocket" for the 5, lol. |
#18 | |
#19 | |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
The Bird is the word! |
#20 |
High-tech Redneck
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8 Join Date: Nov 2010
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning. |
#21 |
![]() Drives: 2011 2SS, 2008 MB E50, 2004 RAM Join Date: Sep 2010
My netgear router is dual band. I have 3 TVs, my son's xbox, and 1 ipad that run through the 5 ghz connection. Most everything else connects through the 2.4 ghz connection or are wired. I personally have not realized any discernible difference between the two wireless connections. One would expect a difference in favor of the 5 ghz (given it is configured correctly for the given usage). Unfortunately I change just about everything I can on the router so that nothing is “out of the box” to help prevent hacking. With that said, I may have changed something prevents me from realizing a true difference between wireless connections.
#22 | |
LEXi is Sassy and Classy
Drives: 2012 Camaro 2LT RS Boston Acoustic Join Date: Mar 2014
First of all, never use a modem router combo, these generally slower than their counter part.Get a dedicated modem and a Linksys router with wireless N/AC capability so you can support speed over 54Mbps. Secondly, on the system that you're doing the test with. Make sure that your wireless adapter isn't A/B/G. You're only limited to 54Mbps with these. Finally, depending on the strength of the wireless signal or if there are any interference, you may not get the 100Mbps advertised. I recommend you looking in to a wireless Power line solution by Linksys. All you need to do is plug the modem in to the source power line hub. Plug any additional wireless hub in rooms of your house. This will ensure 100% signal where ever you go. Thanks |
#23 |
![]() ![]() ![]() ![]() Drives: '14 Z51 3LT Stingray and '13 Cruze Join Date: Feb 2010
Also remember that most ISP's rate their throughput in megabits, while your computer or speed test may be displaying megabytes.
100 Mbps is actually 12.5 MBps. I see people make this mistake all the time. I should clarify by saying it doesn't sound like that's what you're doing, but I'm not sure what tool you're using to verify your speed.
"We have a mental health problem disguised as a gun problem, and a tyranny problem disguised as a security problem."
"What is a moderate interpretation of the text? Halfway between what it really means and what you'd like it to mean?" -Antonin Scalia |
#24 | |
As for the wireless computer and not being A/B/G, i'm not sure what that means. The wireless card in my dell is an Intel® Dual Band Wireless-AC 7260 + Bluetooth 4.0, if that helps.
#25 | |
#26 | |
If you're using the one from Cox, it's probably in Mbps to match what they advertise. Even though it's cable, your speeds will depend on how far you are from their trunk, and the number of people you share that connection with. The problems with that aren't as bad as they are with DSL, but it can still suffer if you share with a lot of people.
#27 | |
#28 | |
