Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 06-28-2014, 06:36 PM   #15
brt3
Runs with scissors...
brt3's Avatar
Drives: '14 Z/28s SIM/SW
Some thoughts about tires. First, I have a set of Yokohama AD08-Rs on the way and will report back my thoughts on how I like them.
Second, here are some photos of my Pirelli Trofeo R tires after 3 track days -- one at Sears Point, and two at Thunderhill in very hot conditions. I think the Trofeo R's are wearing better than I expected; it will be interesting to see how many more laps I can get out of them...
LEFT REAR:
LEFT FRONT:
RIGHT FRONT:
RIGHT REAR:
brt3 is offline   Reply With Quote
Old 06-29-2014, 09:24 AM   #16
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
I would like to have a set of tires I could run on the street, that would't throw crap all over the rear fenders-rock chips, ect.
Suggestions for those?
Angela
350 HRSS is offline   Reply With Quote
Old 06-29-2014, 09:45 AM   #17
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
My car is white and white is always supposed to hide dirt better but after washing her I take a speed run to dry and in 2 miles she is dirty again back on the lower door and rear fenders.
Hopefully Skylane is working on a kit to run these http://goo.gl/JvHUrj
"PTM11" Search & Destroy
backtotintops is offline   Reply With Quote
Old 06-29-2014, 12:20 PM   #18
brt3
brt3's Avatar
See first post in thread...
Old 06-29-2014, 04:01 PM   #19
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
How do we match the TPS to the car? I have my wheels and also 4 sensors, but never made the sensor match, how is that done.
Skylane765 is offline   Reply With Quote
Old 06-29-2014, 04:08 PM   #20
Skylane765
Skylane765's Avatar
We only let the guy advertise the mud guards on our site, but now are the rock guards still available? The ZL1 rock guards will work. Where do we get them?
I can get them made easy.
Old 06-29-2014, 04:53 PM   #21
brt3
brt3's Avatar
1. Buy one of THESE
2. You enter the TPMS reset menu via the DIC display. You go to the TPMS display and then hit "select" to get into the reset/programming mode.
3. Once into the reset mode, and starting at the driver's side front tire, you simply go in a clockwise pattern (seen from above) to reset each TPMS. The car gives you feedback by honking when a TPMS connection has been made.
Old 07-03-2014, 09:05 AM   #22
backtotintops
Drives: 14 Z/28 0#
even though it says it doesn't..this works on the z with the factory tpms sensors also vettes and ctsvs http://www.tirerack.com/accessories/detail.jsp?ID=177
Old 07-03-2014, 09:17 AM   #23
backtotintops
Drives: 14 Z/28 0#
here are my tires after roughly 400 miles and 6.5hrs in some initial street miles, 1 autox and 3 DE track days. All brake pads are even at 9.34cm.
Old 07-03-2014, 09:45 AM   #24
McRat
McRat's Avatar
Drives: 2010 ZR1 "Satan"
Up to 2011, GM's did not need a tool. Now they do. I will train yours for free for just to test my tool on Z/28's.
SIDEBAR:
You don't have to buy GM sensors either, they are becoming universal. Major brands like VDO are selling sensors that are better than OEM pieces at less than half OEM dealer price. They train faster and seal better.
In fact, some cars come with rubber TPMS valve stems which are illegal for many kinds of racing; they must be metal. VDO sensors are metal. Look for SE10001HP - http://www.amazon.com/VDO-SE10001HP-...ords=SE10001HP
Half the price of TireRack or OEM.
2002 Z06 "Blue Meanie" 11.36 ET
2003 Z06 in progress
2009 CTS-V "Spooky" 12.36 ET, bone stock at 1600 mi. Rainy day in Sacramento. Sadness.
2010 ZR1 "Satan" no times yet.
2013 Volt SCCA Solo2 #771 HS3.
And a bunch of Duramaxes.
McRat is offline   Reply With Quote
Old 07-03-2014, 09:50 AM   #25
Zfatuated
Zfatuated's Avatar
Drives: BAC Mono
If you have not already maxed out the front camber I suggest doing so, you are on the sidewalls a bit. Other than that, it looks perfectly normal and expected.
2014 Z/28, White
"I wasn't asked to make it cheap...I was asked to make it FAST!" Mark Stielow, the new Z/28.
Zfatuated is offline   Reply With Quote
Old 07-03-2014, 09:56 AM   #26
backtotintops
Drives: 14 Z/28 0#
yes thanks...I see that. I am running stock alignment as I drive this all the time on the street and would prefer less wear. Could this sidewall wear have been from that one autox (10) one minute runs in 80 degrees ambient but the tires were too low at 34 and not up higher as some on this board have said you need to do for autox??? The car was also run by an autox instructor very hard for 2 runs and then I spun around completely in another run with all nanny's off....or do you think this was totally done on a track by less than full race alignment???
Old 07-03-2014, 10:27 AM   #27
McRat
McRat's Avatar
IMO -
AutoX is brutal on front tires with heavy cars. It has to rotate a 4000lb object instantly, with essentially 1 front tire. You often have to run 40lb in the fronts on heavy cars to avoid tire damage.
You must also "give it up" more before corners. Smooth braking, but a LOT of it is required. Trail braking in AutoX is a no-no, you will understeer.
Old 07-03-2014, 10:45 AM   #28
Zfatuated
Zfatuated's Avatar
Drives: BAC Mono
Hard to say with certainty. McRat makes excellent points. I have sidewall wear on my outboard rear (RR tire/CCW track) from running a bit too low pressures - 29-30 psi.
Camber does not accelerate wear during street driving, it's a common misconception. I have a friend who has 18k street miles on a set of Trofeos running -3.5 front camber.
2014 Z/28, White
