TireRack
Old 05-29-2014, 02:34 PM   #15
zfuzz
zfuzz's Avatar
Drives: 69 Z28 / 12 ZL1
Hey Chase, regarding the Pfadt springs I just stumbled across this thread http://www.camaro5.com/forums/showthread.php?t=214262 that was started in 2012. It discusses the Pfadt springs /isalators and spring noise.
The image below is what Pfadt said was the proper position for the isolators on the rear springs.
Here is an image of the springs that I just purchased. The rears appear to have the isolator in the same spot. My question is this still correct and is there a right and wrong position for the isolators on the front springs. It appears they come with two.
zfuzz is offline   Reply With Quote
Old 06-22-2014, 09:40 AM   #16
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by Dropspeed View Post
Pedders claims they are a "linear rate" and I received that text from an email I sent to Pedders AU after Pedders USA closed shop. It was very interesting to me as before I got them Pedders USA stated the spring rates were higher than the stock springs rates, but would not provide the rates. My car sits 14/15mm lower in the front and 30/35mm lower in the rear with the Pedders set-up.
What is the difference between a linear rate spring and a dual or multi rate spring? Assuming all Gen5 drops springs that are installed on a stock strut (not coilovers) have to be one or the other.
Thanks,
Matt
The spring on the left in the picture below is a true linear rate spring. The coil size and spacing is the same throughout it's entire length.
The middle spring is the dual rate. You can see that there are two distinct regions at the top and the bottom of the spring. It is kind of like stacking linear rate springs on top of each other. The first part of the spring that compresses may have a softer rate, like the 130lbs number mentioned previously, to soak up pot holes and bumps and then it jumps to a stiffer rate after that.
Then, while not being the best visual example, on the right is the progressive rate spring. The coil diameter gets progressively wider from top to bottom on this one. The picture I posted in the OP is a much better example.
Originally Posted by kream88 View Post
Great read lots of great information.
Originally Posted by billk View Post
Thanks for the info Chase! I was just coming on here today to order springs for my 1LE. Perfect timing!
Glad it was helpful.
The isolators should be placed properly right out of the box.
Apex Motorsports is offline   Reply With Quote
Old 06-22-2014, 01:24 PM   #17
DP Valentino
DP Valentino's Avatar
Drives: 2010 CGM Chevrolet Camaro LS
I definitely know about high/low slopped driveways, speed bumps, and dips in the middle of the street Because here in L.A there is a $#!t load of them, and I have scrapped my car on them a couple of time while riding! Overall good informative post!
DP Valentino is offline   Reply With Quote
Old 08-12-2014, 06:09 PM   #18
Apex Motorsports
You definitely have to have more situational awareness after you lower a car. Thank you.
Old 08-12-2014, 06:59 PM   #19
mwendorf3
mwendorf3's Avatar
Drives: 2013 SS Vert IOM
Great post and helped me decide as well as some PM messages from Apex. I just placed my order tonight for BMR 1" drop springs and Sways for my 2013. Can't wait to get them installed soon..
Thanks for the info.
Marvin
mwendorf3 is offline   Reply With Quote
Old 08-20-2014, 06:43 AM   #20
Apex Motorsports
Marvin
No problem. Thank you for your order.
Old 08-22-2014, 07:08 PM   #21
jschlitz2
Drives: 2012 Camaro 2 LT RS
Hey Chase by looking at the picture of the springs ion the box, which would be front and which would be rear?
jschlitz2 is offline   Reply With Quote
Old 09-02-2014, 07:11 PM   #22
Apex Motorsports
The middle two are the fronts, the outer two are the rears.
Old 09-02-2014, 08:18 PM   #23
CCMADONNA
CCMADONNA's Avatar
Drives: 2014 SW 2SS/RS
Chase, you gave me some information a couple of months back regarding lowering my car. If you could please be more specific to the issues involved in lowering a convertible. I am not interesting in going to the track, and I don't want noise, just a nice ride with a slightly lowered stance. Thank you
2014 2SS/RS VERT L99
SUMMIT WHITE
AIRAID CAI
BORLA ATAK CAT-BACK EXHAUST
ELITE ENGINEERING CATCH-CAN
RANGE AFM-DELETE MODULE
HUPER OPTIK 40
CHROME PEDALS
PREMIUM FLOOR MATS
PREMIUM CARGO MAT
DEDICATED 32GB iPHONE HD
[/I][/B][IMG][/IMG]
CCMADONNA is offline   Reply With Quote
Old 09-03-2014, 12:53 PM   #24
bluerl10
Drives: Imperial Blue 2010 Camaro SS RS
What "supporting modifications" are require if any for lowering springs? 1-1.5" more specifically.
Is an alignment required after install?
bluerl10 is offline   Reply With Quote
Old 09-03-2014, 01:00 PM   #25
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Anytime you raise, lower or alter the suspension an alignment is required.
Dropspeed is offline   Reply With Quote
Old 09-03-2014, 06:20 PM   #26
mpiersd
mpiersd's Avatar
Drives: ABM #2041
Funny that I find this thread after the weekend I install my ZL-1 springs.
Good info.
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903
ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | DRL harness | RX Catch Can | Mini me
Cortana: 2015 Harley Davidson Road Glide Special
V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer | Klock Werks 12" Pro-Touring windscreen
Own an Aqua Blue Metallic Camaro?
Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros!
mpiersd is offline   Reply With Quote
Old 09-03-2014, 07:14 PM   #27
Apex Motorsports
Good info.
Of course. Congrats on the upgrade.
Old 09-04-2014, 02:36 PM   #28
mpiersd
mpiersd's Avatar
Drives: ABM #2041
Thanks. Liking the ride, wish it were a little lower, but the price was unbeatable.
apex lowering springs, apex motorsports, best lowering springs, camaro lowering springs
