05-05-2014, 02:32 PM | #15 |
Drives: 2010 Camaro Join Date: Nov 2009
05-05-2014, 02:40 PM | #16 |
Thank you Oshawa/St.Cats!
Drives: was 2010 2LT RS 2G1FC1EV4A9103434 Join Date: May 2009
I've had my Elite Engineering Catch-Can on my 2010 RS for over three years - it pulls about a 1/4 cup of oil every 3 months - highly recommended.
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 - Traded-in 8/31/2019:
05-05-2014, 03:18 PM | #17 |
Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
whats the difference between this and the RX breather?
05-07-2014, 08:16 PM | #18 |
Wow guess elite doesn't want to sell.
Sent from my XT1080 using Tapatalk
05-08-2014, 02:49 PM | #19 |
Drives: Chevys at the limit Join Date: Nov 2010
Their breather is just that; a breather. A breather is not the best option as it allows metered to escape and un-metered air in which can cause lean and rich issues. This system allows the factory designed function at normal operation and also separates and oil that can be drawn back through the system at WOT to prevent oil in the intake system. All in all this is really a more affordable design of the 1LE separator.
Best regards, Tyler 888-308-6007 |
05-08-2014, 03:28 PM | #20 | |
Drives: '12 2LT Convertible Join Date: Mar 2012
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
05-08-2014, 05:30 PM | #21 | |
Any "Empty" can (like most of the inexpensive brands available) will catch some oil, but unless it has a design that will catch all, or nearly all, a good amount will still pass right through. The Elite clean-side separator if you remove the top, you will see a chamber with coalescing media in it that will catch all, or nearly all of the oil and allow it to return to the valve cover after flow direction is again entering. It is only at WOT when intake manifold vacuum is non-existant that the flow reverts through the clean-side and draws oil with it. So size in this case, "doesn't' matter". The empty OEM canisters cannot stop all the oil, it is a very simple unit that slows the ingestion. So no, the Elite unit is far more effective as it directs all vapors through the media where it is trapped and then returned to the valve cover. |
05-09-2014, 11:06 AM | #22 |
Drives: 1LE Join Date: Jul 2011
seriously though... I tried to email your sales department, no answer. My address in Canada keeps being refused on your site so I can't order.... Can I order via PM or email? |
05-09-2014, 12:41 PM | #23 | |
Sorry for the headache, we have been swamped lately (no excuse), shoot us an email or PM and we'll work out the details and get it ordered. sales@eliteengineeringusa.com Thanks for your patience! |
05-09-2014, 12:45 PM | #24 | |
05-09-2014, 02:41 PM | #25 |
Stop writing "vert", ffs!
Drives: 2011 2LT Convertible Join Date: Feb 2012
FYI: PMs not accepted by username Elite Engineering...
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator |
05-09-2014, 02:55 PM | #26 |
05-09-2014, 07:32 PM | #27 | |
"Elite Engineering has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her. If you are trying to send this message to multiple recipients, remove Elite Engineering from the recipient list and send the message again." ...just thought I'd pass the info along.
05-12-2014, 10:01 AM | #28 | |
Hmmm..........I'll check again, thought our settings were correct. |
