Old 01-14-2014, 07:38 PM   #15
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
It'll undercut GM's trucks by a hundred or so pounds depending on cab/bed/engine configuration, but yeah, basically Ford is just catching up in the weight department.
2023 GMC Canyon Elevation
Old 01-14-2014, 07:43 PM   #16
Stevew
Stevew
Drives: 2012 Camaro 2SS and 2012 Corvette
A 1/2 ton truck will not do what I need a truck to do. I am looking forward to seeing the specs on the one ton and maybe even the 3/4 ton. It will be a while. I like the current Ford Super Duties. Hoping my 05 Dodge 3500 4X4 keeps going. The wife is tired of it. I do not want to blow $60K on a new truck.
Stevew is offline   Reply With Quote
Old 01-14-2014, 08:17 PM   #17
SEVEN-OH JOE
Drives: some to distraction
GM may revisit the stillborn 4.5L BabyMax diesel V8. That could be an image-changer AND a game-changer. And don't forget the GM HDs will be renewed for '15.
SEVEN-OH JOE is offline   Reply With Quote
Old 01-14-2014, 09:21 PM   #18
ChrisBlair
Buick 455 Fan
My understanding is that despite Ford's webpage claims, the entire body is not aluminum alloy.
Old 01-14-2014, 09:24 PM   #19
Number 3
Hail to the King baby!
Number 3's Avatar
Aluminum is much more expensive than steel. Ford is now at a major cost disadvantage to GM and Dodge.
But yes it is 700 pounds lighter than THE CURRENT FORD PICKUP.
Old 01-14-2014, 10:44 PM   #20
big hammer
Drives: 2002 ws6
Originally Posted by mikeyg36 View Post
They completely got rid of the 6.2.
the ecoboost is horrible. the only decent engine they have left is the 5.0
Bolt on 2002 ls1 Trans am--- 11.5 @ 121 (1.72) 2000 da
big hammer is offline   Reply With Quote
Old 01-15-2014, 01:18 AM   #21
crysalis_01
Iron fist, lead foot
crysalis_01's Avatar
Drives: 2003 Mustang Cobra
The F150 was 600+ lbs heavier than the Silverado, so they're about equal now.
2WD '14 Silverado ...... 2WD '14 F-150
Crew Cab, 5’ 8” box ...... Supercrew, 5' 6" box
4942 lbs. (4.3L) ...... 5128 lbs. (3.7L)
5042 lbs. (5.3L) ...... 5254 lbs. (5.0L)
5156 lbs. (6.2L) ...... 5296 lbs. (3.5L EB)
Crew Cab, 6’ 6” box ...... Supercrew, 6' 6" box
5000 lbs. (4.3L) ...... n/a
5104 lbs. (5.3L) ...... 5345 lbs. (5.0L)
5216 lbs. (6.2L) ...... 5380 lbs. (3.5L EB)
4WD '14 Silverado ...... 4WD '14 F-150
5139 lbs. (4.3L) ...... n/a
5218 lbs. (5.3L) ...... 5586 lbs. (5.0L)
5370 lbs. (6.2L) ...... 5615 lbs. (3.5L EB)
5197 lbs. (4.3L) ...... n/a
5292 lbs. (5.3L) ...... 5714 lbs. (5.0L)
5429 lbs. (6.2L) ...... 5731 lbs. (3.5L EB)
________________________________________
Double Cab, 6’ 6” box ...... Supercab, 6' 6" box
4860 lbs. (4.3L) ...... 5043 lbs. (3.7L)
4963 lbs. (5.3L) ...... 5169 lbs. (5.0L)
5074 lbs. (6.2L) ...... 5203 lbs. (3.5L EB)
Double cab, 8' box ...... Super cab, 8' box
n/a ............ 5312 lbs. (5.0L)
n/a ............ 5317 lbs. (3.5L EB)
Double Cab, 6’ 6” box ......Supercab, 6' 6" box
5104 lbs. (4.3L) ...... 5333 lbs. (3.7L)
5201 lbs. (5.3L) ...... 5461 lbs. (5.0L)
5352 lbs. (6.2L) ...... 5476 lbs. (3.5L EB)
n/a ............ 5604 lbs. (5.0L)
n/a ............ 5620 lbs. (3.5L EB)
Regular Cab, 6’ 6” box...... Regular cab, 6' 6" box
4387 lbs. (4.3L) ...... 4685 lbs. (3.7L)
4503 lbs. (5.3L) ...... 4791 lbs. (5.0L)
n/a ............ 4953 lbs. (3.5L EB)
Regular Cab, 8’ box ...... Regular cab, 8' box
4567 lbs. (4.3L) ...... 4764 lbs. (3.7L)
4673 lbs. (5.3L) ...... 4901 lbs. (5.0L)
n/a ............ 5073 lbs. (3.5L EB)
Regular Cab, 6’ 6” box ......Regular cab, 6' 6" box
4587 lbs. (4.3L) ...... 4925 lbs. (3.7L)
4707 lbs. (5.3L) ...... 5033 lbs. (5.0L)
n/a ............ 5220 lbs. (3.5L EB)
4816 lbs. (4.3L) ...... 4993 lbs. (3.7L)
4922 lbs. (5.3L) ...... 5130 lbs. (5.0L)
n/a ............ 5375 lbs. (3.5L EB)
These lists were compiled from both ford.com and gm.com, so direct from their respective sources, and I don't think there's a model where the Ford outweighs the GM by "600+" lbs. Now, there may be 6.2L Ford trims that may, but seeing as its being phased out of the 1/2 ton I don't see how it's relevant. Though I'll post those as well if anyone interested. That Boss motor is HEAVY. Either way if the "700 lbs" lost is structural, therefore model wide, the 150 will be in a pretty good spot weight wise vs GM and Ram.
crysalis_01 is offline   Reply With Quote
Old 01-15-2014, 01:33 AM   #22
Stock Boy
Stock Boy's Avatar
Drives: 2014 1LE
I like this truck. I'm down with it. Ecoboosts are awesome if you don't get the dreaded CEL for moisture in the intercooler or whatever they're diagnosing it as. Otherwise they're good to go.
Stock Boy is offline   Reply With Quote
Old 01-15-2014, 10:28 AM   #23
Scrappy Doo
Scrappy Doo's Avatar
Drives: Callaway Rogue
They didn't sell many 6.2's.... And for a $3500 MSRP bump for it I can understand why. LOL
A small percentage of eco's had an intercooler issue. The problem is it's random and that makes it hard to diagnose. (As a sidenote, I seem to remember a lot of GM 5.3's with oil pump issues a few years back...Doesn't mean all 5.3s are junk)
And as a side note on engines, it's not like GM's new 5.3 is a gamechanger
Exactly. (And my f150 is a 5.0..... LOL)
Scrappy Doo is offline   Reply With Quote
Old 01-15-2014, 10:51 AM   #24
HeavyIOM
HeavyIOM's Avatar
Drives: 2010 SS, 2000 Pontiac Formula
This is how I feel about GMs new truck lineup. I feel like GM is 4 years behind, and there new stuff is on par with Ford and Rams old stuff that's been around a few years. I personally don't like the new full size offerings from GM, but they are fine trucks nonetheless. GMs a day late a dollar short IMO
HeavyIOM is offline   Reply With Quote
Old 01-15-2014, 11:27 AM   #25
chain777
Drives: Slow
Thanks for posting that. I knew something didn't add up. It made no sense that the trucks would be close to the same weight now with the extensive use of aluminum in the new F150. Not sure what the "600lbs heavier" comment was based on.
chain777 is offline   Reply With Quote
Old 01-15-2014, 12:40 PM   #26
HeavyIOM
HeavyIOM's Avatar
It was based on comparing the lightest offering from GM to the heaviest from Ford lol
Old 01-15-2014, 02:52 PM   #27
Number 3
Number 3's Avatar
Lost me. Based on the data Ford is no further she'd of GM than GM was ahead of Ford.
Old 01-16-2014, 12:28 AM   #28
big hammer
Drives: 2002 ws6
they're not awesome at all. they have the power of a v7 and the efficiency of a v8, with the complexity of a TTv6. zero advantage at all. in reality, the new 6.2 gm offers a huge power advantage with the same economy, and way less headaches. once the ecoboost gets to 60,000+ miles, it's a maintenance nightmare, with turbo and sensor issues. remember, you're putting your faith in a company to build a TT DI v6 that can't even get a spark plug right.
the ecoboost is far from a game changer. if anything, it's a step backwards.
