#15 |
Master of All Things
Drives: '26 Corvette Stingray Join Date: Jul 2009
I got some really good advice.......have a pro do it!! lol I went and found the materials, and priced it out......I was in the process of building my new home at the time, so I had my builder give me a bid using the same materials. once he gave me the bid, it was a no brainer, I have the pro do the work.
#16 |
Are you planning on using a floor jack or jack stands on the tile?
#17 |
2010 SIM Beige RS 6M
Drives: SIM RS 6M 66 Corvair Silverado LTZ Join Date: Oct 2008
Without a mesh under that you may have cracked tiles wherever there was a concrete crack or stress point. Have you seen how shopping mall floors crack when they place cars in them?
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America |
#18 |
America FVCK Yeah!
Drives: 2024 Z06 Join Date: Mar 2013
#19 | |
America FVCK Yeah!
Like I said I fully expect that I'll have a few broked tiles as I'm just not that good. I'm decent, but no pro. Once they break, I'll chisel them out and replace. No biggie. |
#20 |
![]() ![]() Drives: 2012 IBM 2SS Vert. Join Date: Dec 2011
I'd have done the checkerboard lineoleum to avoid the cracking. If I was afraid of epoxy
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
#21 |
America FVCK Yeah!
OK, all the whole tile is down and I cut all the pieces for the left side tonight. I believe I can get all the cuts done tomorrow after work, leaving Wed - Fri to mortar them up and finish. Sat/Sun will be for grout and trim.
Day 1 = 109 tiles in 3 hours Day 2 = 72 tiles in 2 hours (got home late) Day 3 = 140 tiles in 3 hours (wife and I are starting to get a system. It's called just hand me the tiles and I'll lay them myself.) Day 4 = 170 tiles + 24 cut tiles in 6 hours 480 down and 51 to go!!! ![]()
#22 | |
![]() ![]() Drives: Fast Join Date: Mar 2011
#23 | |
Bully Proof
If you want "to avoid the inevitable crooked grout line" you're supposed to pop a straight chalk line on the floor before you start. I can see that your staggered line is off by a couple inches and even when laid staggered...straight tile lines do matter. And FWIW...I would also add some kind of threshold to the first row of tiles at the entrance because the pressure of the cars going on and off will cause the edges of the tile to start cracking and chipping away pretty quickly.
#24 |
![]() Drives: 2011 CGM 2LT/RS Join Date: May 2011
Anybody care to share a roundabout price to epoxy a two car garage?
#25 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Black 2011 2SS/RS Join Date: May 2011
#26 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Callaway Rogue Join Date: Jul 2009
My new house just got done. I'm going to epoxy in the spring though.
#27 | |
![]() ![]() ![]() ![]() Drives: 2013 2LT/RS Summit White Join Date: Feb 2011
have you been buttering the tile backs?
#28 |
America FVCK Yeah!
No, not at all for this application. I'm using a 1/4" inch trowel and epoxy thinset. The old days of tiling you "back buttered" tile for superior adhesion filling in the anomalies in the tile. I've never back buttered with epoxy thinset as the adhesion is really not my worry anymore. Even thinset and level tiles are my fear with this job.
