#15 |
![]() ![]() ![]() ![]() Drives: 2013 2LT/RS Summit White Join Date: Feb 2011
this is more funny than dumb.
cut a 2x4 with a miter saw and forgot to attach the bag. my helper got a faceful of sawdust. I lol'd.
#16 |
![]() ![]() Drives: 2010 camaro ss Join Date: May 2009
replcing timing belt on father in laws pt cruiser and lowered the car down on a floor jack handle,straight through the right front fender
#17 |
Hating prius's since 1997
Drives: 2010 Camaro 2SS/RS (JENNA) Join Date: Apr 2011
Didnt PQ have a lil accident regarding some wheel
#18 |
![]() Drives: 2010 Chevy Camaro 2SS RS Join Date: Jun 2011
Installed a halo mod. After finishing wanted to back my car up so I could verify it worked correctly. Snow on the ground. When in reverse my foot slipped off of the clutch, car shot back and curled the drivers side door in FTL lol.
#19 |
![]() ![]() ![]() Drives: 2015 SS Sedan M6 Join Date: Dec 2009
After I was pretty much done wiping the wax off of my buddies car, he wanted to see how easy it was to use the portercable to apply wax (there was a small square left)....so he turns it on and was amazed how easy it is..........then he takes the pad off the car with portercable still on....sprays wax all over the car
#20 |
Drives: 2010 RS/SS Join Date: Dec 2010
My dumbest thing? I had just started at a new Dodge dealership as a line mechanic, I was the FNG. I had to go from one side of the shop to the other, and was on my little wheeled stool, so I pushed off from my lift and went rolling across the shop with my arms open, to be funny. I accidentally rolled over the grate, which caught my wheel and my stool, and I went flying. Yeah, hilarious...
Second dumbest thing, also at that dealership, I was probably 19 or so, and I had a pretty serious Snap On 3/8" drive air ratchet. I was working on a Dodge ram and was going to use it to loosen the caliper bolts for a brake job so I had my head in the wheel well up close and personal. The caliper bolt was stuck pretty good, so when I hit the button on the ratchet, it didn't break the bolt loose...the ratchet swung around and whacked me in the jaw, smacking my teeth shut over my tongue. Had to leave work losing like a pint of blood/minute... Oh, those were the days...thank heavens I'm a little older and wiser now! |
#21 |
Turning wrenches
Drives: 2011 Camaro SS By Berger 11BC21 Join Date: Jul 2009
^Sounds like it was seized!!! I had a trans level plug that is only supposed to be 55ftlbs wednesday needing a 1/2 air gun to get it off . . . someone tightened that a little too much!!!!
Sold-2006 Pontiac GTO
M6 1 of 475 353rwhp 353rwtq Sold-2000 Camaro SS A4 Hardtop #867 of 8913 1 of 103 Bright Rally Red Hardtop SS A4 in 2000 1 of 25 and only SIM Camaro By Berger in 2011 year, 2011 Camaro 2SS/RS M6 By Berger #11BC21 |
#22 |
Drives: Eve - 2011 Camaro 2SS/RS Join Date: Apr 2012
I had some spray paint I wanted to test the color of. So, grab my can, raise a piece of paper in the air, spray away. Color was dead on the orange I needed
Pulled the paper down, went to my car, covered in orange over spray ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#23 |
Raised by Wolves
Hubby was just out in the shop moving his vice from where it was to a steel pipe embedded in concrete with a 1/4" steel plate welded to the top of it. He was trying to get the bolt through the hole he'd drilled and spent like 45 minutes trying to clear a path through a welded spot for his bolt to hold the vice on the plate. I come along and ask him what he's doing and he explains.... I ask him - 'can you put the bolt in the other way and put the nut on top?"
Of course it works... and he's just been busting his knuckles trying to make it work the other way. What hurts the most is when your wife points out an easy fix for your miserably difficult task
#24 | |
