#15 |
It will be good for the both of them. Better to work together then against each other while the Asian companies work with each other.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
#16 |
General Motors Aficionado
Drives: 2023 GMC Canyon, 2023 Expedition Join Date: Aug 2008
They've already teamed up on existing 6-speed transmissions.
2023 GMC Canyon Elevation 2023 Ford Expedition SSV (State-Issued) |
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2004 Monte Carlo LS Join Date: Nov 2012
They should have teamed up with the makers of the Fast and Furious series also..
#18 |
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
Is it a Chord or a Fordolet?
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
At some point, wouldn't continuously variable transmissions be a better idea?
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
#20 |
![]() Drives: 14 SS Sedan Join Date: Jul 2008
Huffy already did a 10 speed, this is old technology.
#21 |
![]() ![]() Drives: 2015 Camaro 1SS Join Date: Dec 2011
#22 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
I won't complain about too many speeds, as long as they are smart enough to make it so that in sport mode it locks out the top 2 or 3 gears and holds the other lower gears longer. Also in manual mode I'd hate to have to tap shift through 8+ gears, so would be nice in manual mode to remove some of the in-between gears and only make 6 - 7 of them usable. Should be pretty easy to do with some smart programming in the TCM.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Z/28 #533 Join Date: Jul 2012
I miss the old days where it was 8 cyls matched to a 3 speed tranny. Now we have 3 cyls matched to 8 speed trannys
#24 |
Just a matter of time before the Ford engineered portion of each transmission fails...
#25 |
#26 |
![]() Drives: 2014 Camaro SS 1LE Join Date: Sep 2012
Good for fuel economy but it would suck on an automatic if you can feel the upshift or downshift every time.
#27 |
You'll never feel the shift unless you are on it hard under WOT, and even then, with all the Torque management built in to the software these days, it still can be difficult to really get a good kick out of it. (thats where tuning comes in!) AT WOT, you want to feel those shifts...adds to the fun!
#28 |
![]() ![]() ![]() ![]() Drives: 12 Boss 302 Join Date: Sep 2009
When it breaks on your Silverado, you can blame Ford. When your neighbors F-150 takes a dump, he can blame GM.
The programing strategy doesn't have to use all of the gears from bottom to top. Under hard accel, the transmission could go 1st, 3rd, 6th, 10th. It's all in how the engineers program it. The extra gears just help keep the engine in the optimal range at any speed and load.
The biggest mistakes in life come when you know exactly what you are doing.
