TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 01-25-2013, 09:50 PM   #15
ZOOK
ZOOK's Avatar
Drives: 2010 2ss 6 speed
gears
With the mods that i am doing this winter the gear change was one that i wanted to make the right call .
Thanks for the feedback
ZOOK is offline   Reply With Quote
Old 01-26-2013, 10:44 AM   #16
SC2150
Drives: 2012 Camaro RS, RX supercharged
Originally Posted by flht99b View Post
The LS3 cars should have came with 3.70's from the factory as well as the L99 cars should have come with 3.45's from the factory, IMHO. Guess the EPA fuel numbers might have caused a gas guzzler tax with the increased gear. The seemingly small ratio change makes 6th ( manual ) so much more usable, there is a definite increase in acceleration in all gears ( very noticeable on the road course ), with stock diameter tires 80mph is 2,000 rpm so the car still gets great fuel economy on the road and isn't loud due to engine rpm. With my mild engine mods and 3.70 gears I still get 24.6 mpg on the highway. I'm sure the 3.91's are great also although they might shorten up 1st a bit too much for my taste. Even though the 3.91's weren't out when I installed the 3.70's, if I had it to do all over again I'd still take the 3.70's.
Ed M.
I agree.
Also, anyone wanting we have Diffs in stock complete.
SC2150 is offline   Reply With Quote
Old 01-26-2013, 04:00 PM   #17
NateSS
1337 AH64D driver
NateSS's Avatar
Drives: 2010 Camaro 2SS/RS L99
I'm going to end up doing the same thing.
I dont want to go to aggressive so just the jump up to 3.45 will be enough for me
Cam/Heads by ARD, Tune by G-Force, Transmission/Gears by Circle D
NateSS is offline   Reply With Quote
Old 01-26-2013, 05:43 PM   #18
SGOS252382
SGOS252382's Avatar
Padre swapped his stock gears for LS3, 3:45s. He also documented his track times.
He said the gears made daily driving better (especially once he got his cam), but he didn't see much of any gain at the track.
12.06 @ 114.0 mph - stock gears
12.02 @ 113.9 mph - 3:45 gears
Both times corrected for DA for comparison.
So don't expect much improvement at the track with them.
SGOS252382 is offline   Reply With Quote
Old 01-26-2013, 05:57 PM   #19
Ice Demon
Ice Demon's Avatar
Drives: 2010 Camaro SS
That's depressing lol I was hoping for atleast .3 difference. Could you post a link so I can view that thread.
Mods: "Cam Only"
Ice Demon is offline   Reply With Quote
Old 01-26-2013, 06:18 PM   #20
http://www.camaro5.com/forums/showthread.php?t=128997
Old 01-26-2013, 06:20 PM   #21
Supercharged SS
Drives: 2010 Camaro
When we experimented with gears at the track the 3.45's allowed the car to be in 4th longer, at higher rpms, resulting in higher trap speeds and lower ET's.
Supercharged SS is offline   Reply With Quote
Old 01-26-2013, 06:45 PM   #22
Ice Demon
Ice Demon's Avatar
So it basically seems that if you are looking to improve et's then 3.25 to 3.45 are a waste of $. So I guess I am back to looking at LPE 3.70 gears. I have considered 3.91 but I think they might be to much gear for my auto especially with the insane 1st gear. I would definitely need slicks to get it to hook. I doubt my nt05r could hook. Also with the 3.91 I'm afraid it would shift right before the traps. Are my assumptions about the 3.91's correct?
Mods: "Cam Only"
Old 01-26-2013, 06:48 PM   #23
Supercharged SS
Drives: 2010 Camaro
No it's not a waste. There's a reason all the fast cars are running the 3.45's.
More than likely the 3.91 will be to much gear. What's the rwhp of the car?
Old 01-26-2013, 06:59 PM   #24
Ice Demon
Ice Demon's Avatar
Right now my car just has bolt ons 371rwhp 387rwtq. I also have a stall going in soon.
And I will be going FI in the future.
Mods: "Cam Only"
Old 01-26-2013, 07:02 PM   #25
inferno camaro
inferno camaro's Avatar
Drives: 2010 camaro pace car, 2008 cts bl,
FI= 3.45 in most cases it seems.
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
inferno camaro is offline   Reply With Quote
Old 01-26-2013, 07:03 PM   #26
Supercharged SS
Drives: 2010 Camaro
I'd put the 3.45's and be done with it. You could get away with a 3.91 now but once you go FI forget about that. All you'll do is blow the tires off and cross in 5th.
Old 01-26-2013, 07:10 PM   #27
Ice Demon
Ice Demon's Avatar
Alright so 3.45 will yield minimum gains now but later on it will come into play when I go FI. Yea that's what I thought about the 3.91. Thanks all for the your advice
Mods: "Cam Only"
Old 01-26-2013, 07:15 PM   #28
Motion427
Drives: 2010 2SS/RS Red Jewel L99
If you would have 3.91's and your trap speed would be 120mph. The rpm's would be 6500.
Motion427 is offline   Reply With Quote
