06-12-2012, 09:31 PM | #15 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
This might help some of you trying to figure out what the psi should be with pulley swap:
The stock boost for any Magnacharger TVS 2300 Supercharger Kit installed upon any 2010 - 2012 Camaro 6.2L V8 with a 3.80" Magnacharger Pulley installed on it is only 6 psi at wide open throttle. - 3.60" pulley: expect 2.0 psi. more boost over stock pulley -Total boost 8.0 psi - 3.40" pulley: expect 4.0 psi. more boost over stock pulley -Total boost 10.0 psi - 3.20" pulley: expect 6.0 psi. more boost over stock pulley -Total boost 12.0 psi - 3.10" pulley: expect 7.0 psi. more boost over stock pulley -Total boost 13.0 psi - 3.00" pulley: expect 8.0 psi. more boost over stock pulley -Total boost 14.0 psi - 2.90" pulley: expect 9.0 psi. more boost over stock pulley -Total boost 15.0 psi - 2.80" pulley: expect 10.0 psi. more boost over stock pulley -Total boost 16.0 psi - 2.70" pulley: expect 11.0 psi. more boost over stock pulley -Total boost 17.0 psi PLEASE NOTE: If running Long-Tube Headers, you will lose 2 PSI of Boost and to gain that back, choose a pulley 2 sizes smaller! WARNING: The only way to install the 2.70" Pulley is to have the Jackshaft Housing machined down for it to fit properly. Some Jackshaft Housing Castings are made differently in sizes and do vary, as to what the smallest pulley you can use without maching. The smallest size we recommend is 2.80", without any machining performed on the jackshaft housing casting area.
06-12-2012, 10:35 PM | #16 |
Drives: 2011 Syn Green Camaro Join Date: Sep 2010
The slippage may not be just from the small front pulley or rear drive.
I for one found (after substantial testing) my slippage was from not having sufficient crank wrap. Even though I have a 10-14 rib conversion, an additional pulley was required between the belt tensioner and the overdrive crank pulley to eliminate all slippage. Your standard 6rib may be more capable than most think with this addition.
New Build
5th Gen Camaro, 430ci LSx, Ported Mast 280's, E85 Flex fuel, ID1300's, Squash return, TVS 2300 w/Nitrous Outlet 250 Shot Direct Port, Nano, LPE 10/14 Rib, OD Crank, OD Rear, 2.8" upper, RDS Plate, NW102, 5" Intake, 2" ARH, PATC Built A6, BMR 15" Brake Conv. w/Drag Suspension, Front QA1 DA's, Weld S76 beadlocks & "V" Series fronts. STILL 1k too heavy!!! |
06-12-2012, 11:13 PM | #17 | ||||||||
Booooosted.
Still running the 6 rib system. I think the cog drive is the best way to guarantee it's handled without guessing. Or no? Quote:
Is that the super tensioner I'm hearing about? If so I'm thinking I may be underestimating it. Effectiveness AND cost. Quote:
06-13-2012, 09:11 AM | #18 |
Drives: 2010 SS M6 2016 2SS A8 Join Date: Oct 2009
First of all get an OD setup for the rear belt and put the stock pulley on the front. Then if you want more boost pulley down in front and buy a super tensioner from Ted.
Mine started slipping with just the 3.4 and stock rear pulleys. Having the OD setup on the rear with the 3.8 up front is equivilent to 3.25" on the front according to OLD MOTORHEAD. (hopefully that wasnt too confusing)
TVS 2300 721RWHP 686RWTQ
Built by Me Suspension done by JDP Tune done by JRE |
06-13-2012, 09:11 AM | #19 |
Drives: 08' F250 Diesel & 10' Camaro 2SS Join Date: Nov 2010
PQ don't take this wrong , I know your trying to learn, but you are asking the same questions over and over and not understanding what people are saying. You really should do some simple reading or even go out and study your car and see where the belt wraps the S/C pulley and the crank pulley and see where the tensioner is located and get a general understanding of how the system works.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets |
06-13-2012, 10:00 AM | #20 | ||
Booooosted.
I follow what you guys are saying but in order to know exactly what I need for my car I want to know what all of this means together. I've done things to this point by not learning more about why I was doing them and not just WHAT the parts were and I'm sitting here with the wrong set-up on my car. I believe it makes sense, I want to know WHY it makes sense. Example. I get that a super tensioner will take care of belt slippage better than a stock tensioner (and yes, I've had my tensioner off many times, I know what it does) but is the super tensioner the end all be all? Will it stop all belt slippage? Is that all I need? And if NOT. If there is still a possibility of my belt slipping then I'd rather not spend the money if a cog drive and bigger pulley on front do the trick. I don't have anyone here in Lower Alabama who knows anything about this stuff that I've found. I don't have the time or money to do a bunch of trial and error part swapping and I don't have the luxury of past experience. This is my first blown car. So is a supertensioner all I need? If it can't be said with certainty then what CAN be said with certainty? And if nothing can then I learned something that I had not been told yet. My biggest problem is that I have nobody to just take my car to. I have to do it all. And I have to find out on here. I've already ended up with stuff on my car that isn't working. I'd love to have someone here to take it to and them dyno it and tell me "You need this, this, and this, and that's it." But I don't have that. I have to rely on you guys. Much of this is learned by trial and error and personal experience. It mostly makes sense but some things are not cut and dry. Like the tiny front pulley. I know I can be frustrating to try and answer but I guarantee I'm not the only one. I ask questions that some are afraid to ask. And I still don't know why they sell these tiny pulleys when they don't work. From what I gather, a supertensioner isn't going to guarantee this tiny pulley will work either. If I'm to understand what you are telling me I should buy the cog set-up AND the supertensioner? |
06-13-2012, 10:12 AM | #21 |
Booooosted.
Plus there is the possibility that the belt isn't slipping but there is another factor. I'm working on getting my cam specs for Ted.
06-13-2012, 10:16 AM | #22 | |
Drives: 2010 Camaro Join Date: Feb 2010
06-13-2012, 10:21 AM | #23 | |
This is exactly what I am talking about. You keep asking "will the super tensioner fix belt slip" and " if not I will get the cog drive". Well they have NOTHING at ALL to do with each other or even the same belt or belt tension. The Super tensioner will increase your tension on the belt that runs off of the crank and drives the 3.2 S/C pulley, the COG is on the rear of the S/C and has nothing to do with the slip or tightness of the belt that the super tensioner tightens. Also the super tensioner CANNOT improve crank belt wrap as you asked earlier in a post it will only have better tension that the stock tensioner. I don't mean to come off as an ass ,even though it may seem like it. But I think you really need to look at the set-up and if you did put on the S/C yourself then all this should be self explanitory and its just down to a decision on what to buy. Nobody is going to tell you anything is the end all to ALL belt slip because I don't think anything is to that point everyone is stll growing through all of this. In my opinion the Supertensioner works, as it gets tighter with RPM it pulls away from the pulley on the Maggie set-up which lessons your belt wrap. I was looking at some way to put another slide idler pulley in to keep good belt wrap at high RPM with it but just doesn't seem like enough room.
06-13-2012, 10:25 AM | #24 | |
06-13-2012, 10:29 AM | #25 |
I know, it just seems like he keeps saying something different every post and getting things mixed up. Maybe I am just not following him. When all of the info has been posted and all the answers given. It seems to just not be getting through.
06-13-2012, 10:30 AM | #26 | |
Booooosted.
I get how it works. I know where the cog drive goes and how it works. I know what the supertensioner does and where it goes and how it works. I only wanted to confirm that the supertensioner is not the way for me to go because I can not be guaranteed that it will stop all of the slippage. And the cog drive will take care of it because I'll have much more belt wrap on front and if there were slippage on the rear too, then the cog drive would take care of that as well even though it would be two new pulleys anyway. Form what I am gathering, the supertensioner is really not in the equation because a 2.8" pulley is STILL too small for a 6 rib stock belt. I guess the confusion is that the supertensioner is still in the conversation? |
06-13-2012, 10:37 AM | #27 | |
06-13-2012, 10:37 AM | #28 |
You shouldnt need the supertensioner if you use the 3.8" front pulley, any thing smaller than 3.8 up front will need the supertensioner in my opinion.
